Old 11-13-2019, 12:43 PM   #1
GAD
GAD's Avatar
Drives: Silver 2014 Camaro 2SS
MAP sensor question.
Check engine light just came on. The code is P0106: manifold Absolute Pressure/BARO Sensor out of range.
Can anyone point me to a video or diagram where this sensor is located. Google didn’t come up with anything for my specific car.
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
GAD is offline   Reply With Quote
Old 11-13-2019, 12:52 PM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
Out of range means you might want your tuner to take a look. You might want to get a 2 bar. The sensor should be on the front of the manifold, passenger side if I can remember correctly. Early LS motors they were in the back.
Juiced1 is offline   Reply With Quote
Old 11-13-2019, 12:55 PM   #3
GAD
GAD's Avatar
Ok thanks. I’ll call him up before I replace it. Thank you.
Old 11-13-2019, 05:12 PM   #4
cookiecdcmk
Drives: 2017 Camaro
Fix Attempt
Try cleaning the throttle body plates with some throttle bottle cleaner. It is an easy try to see if it fixes this code. If it does not work, you have not spent much time or money.
cookiecdcmk is offline   Reply With Quote
Old 11-13-2019, 06:25 PM   #5
GAD
GAD's Avatar
Talk to my tuner. He said if the car is still running as normal then the cold weather is colder than the perimeters of the tune. I’m going to swing by and have him cut it off.
