Old 01-08-2020, 08:04 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
What will it make?
Currently have 2014 1LE with BTR stage 4 cam, speed engineering LTS. Made 490-500rwhp. Looking to add some boost.
What will be the power output on the V3Si, or the ECS kit. There’s a 1k difference in terms of price between the 2. Just looking for a reason not to spend the extra 1k. I’m looking for a budget build, since the car is more for leisure pulls. I’m wanting to get 700rwhp it close to that.
RupertPupkin is offline   Reply With Quote
Old 01-08-2020, 08:11 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
For 700rwhp you'll need more fuel..
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 01-08-2020, 08:18 PM   #3
RupertPupkin
That I know. Planning on sticking with pump gas. The V3 kit comes with 880cc Siemens Deka injectors. Or the ECS kit will have FIC 1000cc. Hopefully that’ll be enough.
Old 01-08-2020, 08:19 PM   #4
Rons1le
Rons1le's Avatar
I meant fuel pump
Old 01-08-2020, 08:45 PM   #5
RupertPupkin
I meant fuel pump
Zl1 pump can’t handle it?
Old 01-08-2020, 08:55 PM   #6
Rons1le
Rons1le's Avatar
From what I'm told no 680rwhp is about max on ZL1 pump. I made 661rwhp on 93 with 10lbs of boost and I don't think my pressure dropped any.
Old 01-08-2020, 09:46 PM   #7
RupertPupkin
Did you just keep it at that? Or did you add BAP, or swap out pumps?
Old 01-08-2020, 09:56 PM   #8
Rons1le
Rons1le's Avatar
I have not went any further yet. When I get a cam installed that will tell the story.
