Old 01-14-2020, 03:10 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
TRANS COOLER QUESTION
Hi guys. So i am in the middle of my build. I purchased a 40k tru cool trans cooler and am curious how you guys installed it. I have a 15 camaro ss with a 6L80E. Which line is the feed and return on the bottom of the rad and how did you guys safely make the connection? Any better option than what I'm doing here? Will be running a 3800 stall. Thanks Ryan
gunchamp is offline   Reply With Quote
Old 01-14-2020, 06:32 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
This may help:
https://www.camaro5.com/forums/showp...postcount=1689
https://www.camaro5.com/forums/showp...postcount=1702
https://www.camaro5.com/forums/showp...postcount=1703
https://www.camaro5.com/forums/showp...postcount=1709
I used my original adm hoses and made it work...
I road raced and my trans temps were fantastic...
My build thread (yes it’s long) show the ADM kit install and also when I went with the bigger B&M cooler. I have a lot of other experiments too ;o)
-Don
747 RWHP 794 RWTQ
Old 01-14-2020, 08:54 PM   #3
gunchamp
gunchamp's Avatar
Thank you for the links. So all i have to do is cut one of my lines and add a compression style AN fitting to adapt to the factory lines? Looks like i can cut the end off one of my factory lines and go from there
Old 01-14-2020, 08:56 PM   #4
gunchamp
gunchamp's Avatar
Should i still use the factory cooler? I bought a mishimoto radiator so im thinking i should go through that and then into the trucool cooler then back to the trans?
Old 01-14-2020, 10:37 PM   #5
hammdo
hammdo's Avatar
I bypassed the factory cooler. I also got a kit from ADM — made the install easier.
Andy may still have those...
-Don
747 RWHP 794 RWTQ
Old 01-14-2020, 11:12 PM   #6
gunchamp
gunchamp's Avatar
Cant seem to find that kit. Wasnt sure if it was beneficial to bypass my cooler built in to the aftermarket radiator
Old 01-14-2020, 11:19 PM   #7
hammdo
hammdo's Avatar
I did and I have a CSF radiator too...
Kit may be here:
https://lsa-conversion-store.myshopify.com/
-Don
747 RWHP 794 RWTQ
Old 01-15-2020, 07:48 AM   #8
gtstorey
I bypassed my radiator cooler, but did add in the thermostat control. I was afraid that during cold weather, it would take way to long to come up to temp. Even with the thermostat it takes a while, and I think this may have been the cause of some my "shift flare".
gtstorey is online now   Reply With Quote
Old 01-15-2020, 08:52 AM   #9
gunchamp
gunchamp's Avatar
Hmm ok. I may go through my radiator first, although I really dont drive in the cold.
Old 01-18-2020, 04:26 AM   #10
hou30guy
Drives: 2011 convertible 2ss/rs
I bypass my stock one and got a 30 row cooler with 7" fan and my temps stay 180 or lower and i had 3200 stall now i have a 4k stall
hou30guy is offline   Reply With Quote
Old 01-24-2020, 10:02 AM   #11
gunchamp
gunchamp's Avatar
Thank you for the feed back
