Old 02-09-2020, 03:47 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
AFR gauge or Lamda Gauge
Would just an AFR gauge suffice, or should I get a Lamda gauge? Planning on biting the bullet and do e85 with the build. What do you guys use?
RupertPupkin is offline   Reply With Quote
Old 02-09-2020, 05:16 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
With an AEM setup you can switch between the two....Lamda being simplest to read
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 02-09-2020, 05:19 PM   #3
RupertPupkin
I was looking at that gauge..
Old 02-09-2020, 05:37 PM   #4
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
I have that one and love it! Reads through hp tuners with obd2 connector.
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 02-09-2020, 05:57 PM   #5
RupertPupkin
Is this the 1 you have? AEM Wideband UEGO Gauge - Digital Air/Fuel - 30-4110
So from what I read, if the mixture is good, it’s always going to read 1?
What numbers usually pop up during WOT?
Old 02-09-2020, 06:11 PM   #6
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
You should see around stoich 1.00 lambda (14.68 air-fuel) during idle and cruise, but it will fluctuate like a sine wave up and down, maybe 2-5% depending on how your O2's are cycling fueling.
WOT readings will read how the car supposed to be tuned: maybe around 0.80 to 0.84 lambda (11.7 to 12.3 AFF) for N/A, maybe 0.74 to 0.78 (10.8 to 11.5 AFR) for FI.
Fueling gauges are lambda reading gauges, and just calculate and output the reading in AFR (derived from lambda). Nice thing about lambda is that you don't need to know the AFR for each fuel - it's just a consistent scale that reads what "percent" of stoichiometric you are running.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 02-09-2020, 06:13 PM   #7
RupertPupkin
Originally Posted by dreksnot View Post
You should see around stoich 1.000 lambda (14.68 air-fuel) during idle and cruise, but it will fluctuate like a sine wave up and down, maybe 2-5% depending on how your O2's are cycling fueling.
WOT readings will read how the car supposed to be tuned: maybe around 0.80 to 0.84 lambda (11.75 to 12.3 AFF) for N/A, maybe 0.74 to 0.78 (10.8 to 11.5 AFR) for FI.
So .74-.78 for e85 also at wot?
Old 02-09-2020, 06:15 PM   #8
dreksnot
dreksnot's Avatar
Depends on your build, but yes, that's close. Generally, the more boost I push, the more fuel I'll run - to keep things happily fueled and "cool."
Old 02-09-2020, 06:18 PM   #9
eLeSthree
Drives: 2011 Camaro SS 6sp
Aem Uego also. In my logs i show lambda, on the gauge i left it as afr. Its just more natural to me and I can react quicker to 12.5 than i can .85. I dont know why. With lambda i tend to take .5 seconds to calculate.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 02-09-2020, 06:33 PM   #10
Big Biscuits
Same here^^^
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Old 02-09-2020, 06:51 PM   #11
RupertPupkin
I’m at ground 0, so idk what numbers I should see, or what’s good. I know that different alcohol percentage could change that reading also..
Old 02-09-2020, 06:55 PM   #12
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
It doesn't matter. Once you know what you're supposed to be at you'll know what to look for. My mind works in AFR so if i see lambda i calculate it to AFR so it's better for me to just read AFR and know where i am supposed to be at
Greenhornet2 is offline   Reply With Quote
Old 02-09-2020, 07:23 PM   #13
Silver14
Drives: 2014 SIM 2SS
I have that gauge, no complaints. I am only using 93 octane at this time, haven't switched to e85 yet.
Keep in mind e85 isn't always exactly e85, stoich will change based on the ethanol content. AFR you'll need to do a conversion, with lambda, it doesn't matter.
Silver14 is offline   Reply With Quote
Old 02-10-2020, 06:00 AM   #14
eLeSthree
then teach yourself to read lambda. 1.0 is cruising/idling and most likely your target in boost will be around .78
Dont get confused with the different stoichs of each fuel. Who is going to tune it?
Have you started a pile of parts yet?
1158whp 1017wtq.
630whp 658wtq
