Old 03-22-2020, 07:14 PM   #1
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
What am I forgetting?
So I bought a Whipple 2.9 kit to bolt on to my 1LE but during my "while you're at it" I discovered a crack in one of my sleeves. I have since found a slightly used LSA bottom end and AFR heads so I'm doing my own build. My goal is to be around 650 at the wheels when I'm done.
I expect I'll be borderline with the injectors that come with the kit but I'm also trying to make sure I replace anything that will be difficult to do later. For example, I have a new monster clutch on the way. I already have a trunion upgrade, PDS stage 3 cam, melling oil pump, lifters, head studs, etc.
For those that have gone through the process, what's the one thing that you wish you had done while you had everything apart for your build?
Sent from my Pixel XL using Tapatalk
Old 03-22-2020, 08:27 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Upgraded fuel pump.
Vegas Bound is offline   Reply With Quote
Old 03-22-2020, 10:27 PM   #3
larry_g
larry_g's Avatar
Originally Posted by Vegas Bound View Post
Upgraded fuel pump.
1LE already has a ZL1 fuel pump and the kit comes with a FPCM. Will that get me to 650 or am I pushing my luck?
Old 03-22-2020, 10:41 PM   #4
Vegas Bound
I guess it depends on the programming in the FPCM and size of injectors. You will probably be close to max. I did 659 whp with a LSX crate motor and LSA supercharger on a ZL1 pump and ADM FPCM. I installed a DSX aux pump and 1300 injectors when I went e85 and swapped pulleys.
Old 03-23-2020, 10:02 AM   #5
larry_g
larry_g's Avatar
Thanks for the input.
Old 03-23-2020, 12:38 PM   #6
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Like Vegas, I got to about 670rwhp on the ZL1 and ADM FPCM. At the time I had 65lb injectors and was running 93 octane.
at 650rwhp, you'll be living on the edge of reliable fuel pressure at WOT upper RPMs.
A boost-a-pump would probably give you a decent safety cushion, but a twin or tripe pump setup would be the better way to go, if the budget supported it.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is online now   Reply With Quote
Old 03-23-2020, 05:24 PM   #7
larry_g
larry_g's Avatar
-Scott
Ok, so I'm probably borderline with fuel but I'm going to wait until after my first trip to the dyno to see where I baseline with the new setup. Especially because I'm probably going to have to swap pulleys to get to my goal.
Those are relatively easy parts to replace... what's the one thing that made you say "shit, I should have done this while I had it all apart"?
Old 03-23-2020, 06:58 PM   #8
Vegas Bound
4L80e swap.
Old 03-23-2020, 10:24 PM   #9
larry_g
larry_g's Avatar
4L80e swap.
LOL... never! I'm old school.
Old 03-23-2020, 10:37 PM   #10
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Might need a bap to get you there, zl1 pump with fpcm programmed and bap should be safe to 725whp without bap might be more like 625. But if i were you, I'd see where you can get it to without the bap then when you want another 150hp get a dsx aux pump and forget the bap
Greenhornet2 is offline   Reply With Quote
Old 03-23-2020, 10:42 PM   #11
Greenhornet2
A lot of people go to the ls2 dogbone timing chain tensioner. If you are doing the clutch i would add the remote bleed replace the slave. A good crank pulley puller. Crank Pin kit, that probably came with your whipple kit.
Old 03-23-2020, 11:05 PM   #12
Vegas Bound
I was until I got back into drag racing. No way I can shift as fast as a computer.
Old 03-23-2020, 11:36 PM   #13
larry_g
larry_g's Avatar
That sounds like a good plan.
Old 03-23-2020, 11:44 PM   #14
larry_g
larry_g's Avatar
Got the dogbone chain guide and the remote bleeder and fresh slave with aluminum bearing support for the clutch.
So everything I have is for an LS3 but I ended up with an LSA short block. The LSA crank has a woodruff key so it doesn't need to be pinned. The ATI LS3 damper hub has a keyway so I'm hoping it bolts right up and maintains the offsets for the LS3 accessories. I won't know if it works until I get a bit farther along with the build.
