Old 03-28-2020, 07:44 PM   #1
Leo72793
Drives: 2011 2SS/RS
Diff bearing failure
Anyone experience diff bearing failure really early? 65k on my car and there is a loud decel howl, and we took it apart and the entire center chunk moves side to side almost half an inch. one bearing looked like this
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 03-28-2020, 07:58 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Things do happen. I see plenty for warranty work with less than 80k miles. A lot of times it was a leak and they started running without fluid though.
Greenhornet2 is offline   Reply With Quote
Old 03-28-2020, 09:07 PM   #3
Leo72793
Drives: 2011 2SS/RS
Im pretty careful at making sure i dont leak fluids. i dont like the smell of diff fluid. it sprung a leak, changed the seal and didnt leak for a week then started again. always made sure the fluid was full unless i didnt drive it ( recently 2 weeks no driving) but yeah. all of them are like this some worse than others. the front pinion race was really bad but the bearing looked fine but not worth the risk. I have new SKF bearings and seals for the axle and a motive kit coming for the pinion bearing and seals since national is completely out of stock right now. Ill be going to a 3.45. the 3.73 i want are way too expensive so for now this will work. My tuner is updating the file.
Old 03-28-2020, 09:42 PM   #4
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Yes, I've had a bad carrier bearing and pinion bearing. Can also sound like marbles rattling around in the diff. Mine did it at around 32,xxx miles. It happens, even with all the maintenance in the world done.
More to come.
Black_SS10 is offline   Reply With Quote
Old 03-29-2020, 09:12 AM   #5
Greenhornet2
Consider 3.91s? They work really well in these cars and are not too expensive.
Old 03-29-2020, 11:56 AM   #6
Leo72793
Drives: 2011 2SS/RS
Nope. not even considering it because i daily drive a stock motor car, and its highway for work.
Old 03-29-2020, 11:57 AM   #7
Leo72793
Drives: 2011 2SS/RS
Funny part, no noise at all except a slight decel howl. NOTHING else. no clinking, clunking etc
Old 03-30-2020, 07:05 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
You won’t notice that much of a difference in the 3.91’s I’ve got‘em in my 10SS and still get 24’ish on the highway doing 80
Orange Krush II
Old 03-30-2020, 07:59 AM   #9
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
Mine lost a bearing at about 4000 miles.
2011 Synenergy Green 2SS/RS Automatic.
Hulk is offline   Reply With Quote
