Old 12-21-2009, 10:22 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
General question on Stainless Headers
Do Stainless headers ever change color? I know they won't rust but do they change to a bronze color or anything like that? Do you think they'll look the same 10+ yrs from now as the day you put them on?
I'm wondering if it would be best to ceramic coat them before installation? I use ceramic coated headders on my Firt Gens but that's mostly to keep them looking the same over the years and not just the fact that they should keep the engine bay a little cooler.
(I was always told ceramic helps keep the heat from the exhaust gettin into the engine bay)
Build Journal
Old 12-21-2009, 10:26 AM   #2
toehead93
Drives: 2014 2SS/1LE
My last set changed colors and I eventually had them coated. I just bought a used set with 50 miles on them for my 2010 SS and they already started to change.
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-21-2009, 11:08 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I had a set of polished stainless QTPs on my last car and they changed to a golden-bronze color after the first drive. If you keep oil and other chemicals off them, they can look very good for a long time. I'm not too big a fan of coatings because all of the ones I've seen fail after a little while. Why pay a couple hundred bucks for coating when you could spend like $70 for sanding materials, high temp' primer and silicone-based header paint. I've had nothing but great luck with VHT and DFI, even on mild-steel. If money isn't a big issue, and you like it better, coat 'em; if not, save it and take some time and do it yourself, IMVHO
'20 ZL1 Black "Fury"
just installed stainless works headers (videos inside) o2camaross Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 09-30-2009 07:39 PM
Question for those that have installed SW Headers Scourage Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 09-15-2009 04:36 PM
