Old 05-08-2020, 01:18 AM   #1
BIG NASST
Drives: 2013 2ss hotwheels
SW vs corsa
https://youtu.be/gC8SH6WPb2I
https://youtu.be/eoadJgnr7V0
BIG NASST is offline   Reply With Quote
Old 05-08-2020, 01:25 AM   #2
BIG NASST
Mine is SW in both vids.I've heard em both. I love SW set up, deeper no drone.
Old 05-08-2020, 07:08 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Damn that car is beautiful. I love that color. Sounds great too. I have always liked the sound of the SW retro exhaust. I still prefer the Corsa Xtreme, but I have neither installed, so take that for what it's worth.
Honestly, you cannot go wrong with either setup.
Old 05-08-2020, 07:28 PM   #4
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
If I didn't already have the Corsa Xtreme I would have the Stainless Works Retro Chamberd catback
Modernmusclecar is offline   Reply With Quote
Old 05-08-2020, 11:31 PM   #5
BIG NASST
Thanks guys they both sound good . I'm just talking sh%$# .that way I can hear some good clips.
Old 05-11-2020, 12:51 PM   #6
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
It came down to these 2 for me as well, but liked the corsa extreme a little better. Some of the claims out there that SW is a big restriction turned me away as well.
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-11-2020, 02:33 PM   #7
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I've always liked the SW retro chambered catback. A buddy of mine has it on his car and it is just a nice deep sounding exhaust.
Of course I had to laugh at the first video when you all but crapped your pants while running over the power cord or bucket lid. It made me jump too, but the look on your face was priceless!
Check out my build thread
Old 05-11-2020, 03:29 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
I was going to bring that up but I didn't want to open a can of worms. The muffler design they use necks down quite a bit inside. Also, they sell a similar exhaust setup but with turbo style mufflers instead. Those were tested on a dyno on a CTS-V (Youtube video by RPM Motorsports I believe) and were causing a massive loss of HP.
I imagine at my power level it would be no issue at all, but 600rwhp or higher they could be a restriction.
Old 05-11-2020, 03:50 PM   #9
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I am torn between the corsa or leaving the NPP that the car came with.
But I am thinking the 3in exhaust will help my car a lot better. But for now I can't afford the corsa LOL
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 05-11-2020, 03:52 PM   #10
Modernmusclecar
There's a vId that showed cutting open the muffler on the SW. ..it reduced down alot...I dont even think it was 2 inch. But I can't find it now.
Old 05-11-2020, 07:03 PM   #11
RupertPupkin
Drives: 2014 Camaro SS 1Le
NPP FTW!!! I like my NPP muffler on my SS. I did the muffler mod on it though, so it sounds 1000x better than your regular NPP. https://youtu.be/RqBwd1LTDPg
Stick with your 2.5. 3 inch exhaust will only net you 15whp on avg. not worth the cost to power.
Corsas are nice too, I have them on my C6Z
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-11-2020, 07:32 PM   #12
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
I am a strong proponent of catless longtubes, x-pipe, and leaving the rest of the system stock. I think it sounds wicked and I get compliments frequently on how it sounds.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-11-2020, 08:06 PM   #13
Arch-City
Drives: 2015 Camaro 1LE
https://youtu.be/EIO2_ExA290
Kooks Headers, 3" No Cats, and Carven Mufflers.
Arch-City is offline   Reply With Quote
Old 05-11-2020, 09:14 PM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
Arch, is that your car? If so, can you edit the video and list the engine mods you have?
