![]() Drives: Camaro 2LT RS IBM Join Date: Dec 2009
Swirl Marks
Whats the best way to remove swirl marks
Moderator
Drives: '99 Camaro SS #1392 Join Date: Jun 2006
First bit of advice; get used to them.
I'm not trying to sound sarcastic, but they're a fact of life. The best you can do is to try to minimize them, as well as remove some and hide others. ![]() Meguires, Mothers, and a whole host of mfrs. offer products for this problem. But in addition to a good wax/polish, using the proper wash mitts, as well as towels for waxing/polishing and drying is essential. Do a little research in this forum and you'll find answers to all of your questions. Or you can PM me if you can't find an answer and I'll be glad to help. Ed |
Thanks for the quick reply, I see meguiars has a SwirlX product I guess I'll try that out.
Moderator
![]() Drives: Pontiac Solstice GXP Join Date: Apr 2009
Turtle Wax Ice and Mequires NXT work nice for me.
TPW set for 12/ 7...birthed on 12/10...stripes added 14th and ready to ship on the 15th.
11/6/2009 ABM ordered from Smith Stokes, Reidsville, NC 11/18/2009 3000, Order accepted by production control 11/25/2009 3000, Order accepted by production control (second time) 12/3/2009 3300, Order scheduled for production 12/9/2009 3400, Order Broadcast 12/10/2009 3800, Order Produced VIN 2G1FG1EV4A9177814 12/15/2009 4000, Available to Ship from OSH by Railroad |
#6 |
Drives: 2014 Ford Focus ST Join Date: Jun 2009
Help in removing Removing Swirls & Water Spots:
The number one email/Phone calls we receive is a request for help in removing swirls & water spots. ![]() Before starting, it's a good idea to check for paint contamination by placing your hand inside a plastic sandwich bag and running your fingertips over the surface. If the paint is rough or gritty, consider using a clay bar before trying to remove swirls. Here some options: Option #1 Temporarily hide swirls & spots: Swirls can be visually hid by polishing the surface with a non-abrasive polish such as Blackfire Gloss Enhancing Polish, Meguiar's No. 9 Swirl Remover or 3M Perfect-It Swirl Remover. These polishes do not remove swirls. They round off the top edge of the swirl, robbing sunlight of a sharp edge to cause a reflection. When you buff off the polishing residues, fillers will stay in the depressions. ![]() ![]() ![]() Finish by applying your favorite wax or paint sealant. This will hold the fillers in place, cosmetically hiding swirls and minor paint blemishes. This procedure does not remove the swirl. Swirls may be visible in certain light conditions (fluorescent lamps are ruthlessly revealing) and will reappear as the wax ages. That said, most people will look at your car and think it's flawless. Remove the swirl, water spot or paint defect: ![]() Removing a swirl requires you to remove the top layer of paint or clear coat that contains the swirl. This is best accomplished with a circular machine polisher which is designed to remove paint. You literally abrade away the surface until the swirls are gone. Dual-action polishers like the Porter Cable 7424 are not designed to remove paint. They can round over and make invisible minor swirls and spots but may not have the power to fully remove deeper paint defects. To remove a swirl, you must remove the layer of paint or clear coat that contains the defect. These polishers will definitely do a better job than can be accomplished by hand and offer the novice enthusiast the safety of a random orbital motion which will not make the problem worse or introduce additional swirls. Very fine swirls can be removed by polishing alone. Deeper swirls. water spots and/or light scratches typically requires a three-step compound, polish and finish procedure. These are the same three steps used by automakers, body shops and professional detailers. Compounding involves abrading away the area surrounding the scratch or blemish until the defect is no longer visible. This is best accomplished with a circular polisher (DeWalt 849, Makita 9227, etc.) but dual-action polishers like the Porter Cable 7424 will remove minor defects and visually reduce deeper swirls, scratches and blemishes. Compounding may leave the surface dull. This is normal. This dullness, or compounding haze, is removed in the next step which is polishing. Polishing removes compounding haze and restores surface gloss. It creates a mirror-like, highly reflective finish ready for waxing. Finishing protects the surface with your favorite wax or sealant. Finishing can be accomplished by hand or with a dual action polisher (Porter Cable 7424). Applying a wax or paint sealant by machine is typically done with an ultra-soft, foam finishing pad. There is now the Meguiar's M105 & M205 that can be use with your Porter Cable to remove major swirls on GM hard clear coat paint. |
#7 |
GM fix my PAINT U suck!
Drives: 2010 Black 1SS/RS 6Spd Join Date: Sep 2009
Those diagrams are ridiculously exaggerated lol. Thats the depth of a mild keying lol. More accurately the depth for a swirl would be about 1/500 of that. Seriously. Good info though.
#8 |
The camaro get swirls if you breath on it haha. im guessing its some new eco friendly paint and clear their using........ i hate all these green products none of em work as good as the deadly ones.
i guess its a choice you have to make, save the some sorta rain forest fruit bat that is only seen every 20 years to mate and go back under ground a day after doing so.....? or good looking paint on your car? i vote car...... hahah |
#9 |
Love's to Detail
Drives: 2010 SS,97silverado/08crewcab Join Date: Oct 2008
The Megs M105 and M205 combo do work great using the Kevin Brown Method
via PC...Practiced on my 97 truck...it has never looked that good! Followed up with some Pinnacle XMT carnauba, and WOW! |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
Seriously....my car sort of had swirl like light scratches when i picked it up...the prep guys at the dealership probably had stuff in the towels they used to dry my car after they washed it when it came of the truck...
stupid paint!!!!!!!!!!!!
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
#11 |
Detail guys at the dealerships typically don't use the best stuff to detail the cars. Pretty much punching a clock and using the same cloths day after day.
No one will ever take care of our cars as we would.
#12 | |
![]() ![]() ![]() Drives: Transformers Edition Camaro 2SS/RS Join Date: Jan 2010
You are not kidding ! I don't even drive mine, it's in the garage, and I'm afraid to even dust it off. Every time I touch it I find a new mark. I'm scared to even walk by it. These cars paints and "painted" wheels are really so delicate. |
#13 |
![]() Drives: 1972 Z28 Join Date: Mar 2009
I use Maguires swirl remover I bought a bottle at the
Maguires display at the Atlantic City car show/auction they have 2 versions one for buffers [tan bottle] and one for either buff or hand application [black bottle] works really good I use it on my show Monte and my black SuZuki MC |
#14 | |
I noticed my dealer prep guy (who I gave a $20 tip) avoids me.. Hmm... Maybe he saw the scratches too... or made them.. Don't know.. He was nice though. Overall I am happy with my dealer at this point. Most everything else has gone very smoothly.. |
| Any one get dark swirl marks after using Zaino Z8? | loopback | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 2 | 12-01-2009 01:46 PM |
| Surface swirl marks | Ristaze | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 4 | 11-06-2009 04:56 PM |
| How bad do you see swirl marks in your car/color? | Kendell347 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 16 | 08-25-2009 07:51 PM |
| Swirl Marks on Victory Red... | y2jdmbfan | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 27 | 08-11-2009 10:55 PM |
| Camaro on lot with swirl marks! | heidi | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 27 | 07-30-2009 06:44 AM |
