![]() Drives: 2012 Camaro SS 45th Anniversary EU Join Date: Jun 2020
Hi guys,
Look this is on Drive idle. Is this normal? Or low? Dying pump? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
If my math is right that is about 30psi at full temp which I think is about right.
GPI Sales Consultant
If I'm doing this right, that looks like about 187.5KPA, which is 27psi. I would call that reasonable for hot idle in gear. Whats the cold start idle pressure look like?
Got a question about a GPI product? Feel free to shoot me a message! |
285 kpa = 41 psi.
#6 |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
Normal
#8 |
Ahh nice if it is normal... I'm getting paranoia on this car..
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
How long have you had the car and what suddenly drew your attention to the pressure?
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#10 | |
https://www.camaro5.com/forums/showthread.php?t=578098 |
#11 | |
#12 |
#13 |
how many km on it?
#14 |
| Tags |
| l99, oil pressure |
