![]() Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Wire rear view camera into aftermarket radio?
Hi All,
Can you tap into the wiring of the factory rear view camera and run it to an aftermarket head unit? Trying to see if that’s doable or if you need a new camera mounted back there. Thanks! Mike |
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
Pac RPK5-GM4101 dash includes everything you need for the install. Harness, SWC, USB retention, AUX retention, back up camera retention and antenna adapter.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
#3 | |
So if I go PAC, it will forward the signal to my new receiver? I’m hoping to forward the picture and view it on the new head unit since the mirror picture is small and hard to see. |
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i would like to see how to make it work. i thought the pac camera harness was for when you replace the mylink.
I would think you should be able to tap into a couple wires to make it happen? :shrug:
#6 |
![]() Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
The idatalink maestro does this as well , not worth hacking up the harness to find imho.
#7 |
![]() Drives: 2015 Camaro 2SS Green Flash Edition Join Date: May 2017
The PAC kit does not include what you need to tap the factory rear view mirror. That requires a harness from gen5diy. You have a choice on whether you want to have your video remain on your mirror or just move it to your new head unit.
https://www.gen5diy.com/products/12-...-video-harness I chose to keep the video on my mirror. I advise getting an RCA extension as it will not reach behind your radio otherwise. The mirror is a better place for the camera anyway. Don't forget to tap your reverse light to trigger the camera!
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/) Performance Mods: CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust |
#8 | |
Thanks for this. Yeah, wow. Surprised it is so involved to just relocate to the head unit. I am probably just going to keep it on the mirror. Maybe it's worth just installing a second rear camera for $20 and then have both. Seems cheaper/better to me....
#9 |
So different question - Assuming the head unit supports it, can I just go ahead and get a maestro rr but use the PAC kit? Will the maestro rr also relocate the rear view camera to the screen?
#10 | |
No. The Maestro RR is just a different brain interface, and it is independent of your camera. You are faced with the same issue. The Maestro difference is that it has an OBDII interface to route data to your Maestro enabled stereo.
StarSaber Mk. II
#11 |
LEXi is Sassy and Classy
Drives: 2012 Camaro 2LT RS Boston Acoustic Join Date: Mar 2014
The iDatalink Maestro MRR2 and Kit-Cam1 will include the necessary harnesses and adapters for Camaro 2010-2015.
#12 |
#13 |
I found that CAM1 retain a lot more than PAC.
It also can display all diagnostic codes directly onto you radio. I started with PAC too, now swapped over to iDatalink. |
#14 |
It comes down to nothing more than the look of the pac vs idatalink. I just really like the stock look, though the idatalink has been growing on me quite a bit.
