Old 12-25-2009, 11:22 PM   #1
rodimus prime
Drives: Cargo van.
a6 tranny shift properties.
I was messing with my trans settings via hp tuners and came across something you might find interesting.
The shift properties for D and S mode are the same. However TUTD gets its own shift properties. Its labeled as shift pattern y for drive and sport and shift pattern x for TUTD.
When the weather allows I will change my S mode to X to see if it feels any different. Of course I will have to set my trans back to stock again to notice if it does anything.
rodimus prime is offline   Reply With Quote
Old 01-05-2010, 07:13 PM   #2
Roger Ramjet
Motor Head
Roger Ramjet's Avatar
Drives: CTS-V
I noticed that too!
I just modified the TPS vs. MPH downshift lines to make the car more aggressive. I also raised the 0 TPS downshift speeds to use engine braking. Works GOOD!
History Camaro's: 83, 93, 95, 98, & 10.
Roger Ramjet is offline   Reply With Quote
Old 01-05-2010, 11:00 PM   #3
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
By shift properties do you mean shift times? Because these are in fact different between S and D.
2010 IOM 2SS/RS A6, Tuned by Me, ARH/NoCats, Borla Touring, Vararam CAI, G-Force 9" with 4.10's, Circle D 4500K, (Skinnies/Slicks, and Bogarts all around 24MPG
11.39 @ 118 510 DA
www.6l80tuning.com www.6l90tuning.com
Wacker is offline   Reply With Quote
Old 01-05-2010, 11:10 PM   #4
The_Blur
Moderator
The_Blur's Avatar
I'm going to need a much more thorough explanation of this. I am completely unfamiliar with HPTuners.
warn 145:159 ban
Old 01-05-2010, 11:16 PM   #5
rodimus prime
Drives: Cargo van.
I dont remember off the top of my head, Ill look at it again in the morning. It wasnt shift times I dont think. I zeroed all those out.
Mines tuned for a yank 3600 and the whole car feels new. Ill send it to anyone that wants it. The tuning school only charges $79 for the a6 tuning book, I may grab that to fill in the gaps of things I cant figure out.
Old 01-05-2010, 11:17 PM   #6
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
http://www.hptuners.com/forum/showth...=18378&page=16
A great read if you go through all the pages.
11.39 @ 118 510 DA
Old 01-05-2010, 11:19 PM   #7
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
ill give that a read! thxxx
hot ss is offline   Reply With Quote
Old 01-05-2010, 11:20 PM   #8
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Doesn't this tranny go into "Non Adaptive mode" if you zero them out? I know if your adders/multipliers end up giving you a zero thats okay. But adaptive mode is far superior/safer than manual mode.
11.39 @ 118 510 DA
Old 01-05-2010, 11:22 PM   #9
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Here is another.
http://www.hptuners.com/FORUM/showth...=25456&page=13
11.39 @ 118 510 DA
Old 01-05-2010, 11:30 PM   #10
rodimus prime
Drives: Cargo van.
Well again I dont have my tunes or logs with me, but I believe I was looking at stock c6 tunes and noticed the shift times were zeroed out there as well. Again Im going off the top of my head. But with them zeroed out I was logging .1 second shifts. Ill post it up so you can look through it tomorrrow.
I looked through g8 tunes, commadore tunes, ctsv tunes and vette tunes to compare what they did differently.
I also noticed a lot of missing tunes from the repository. I knew I should of snagged more of them.
Old 01-05-2010, 11:33 PM   #11
Wacker
INTHECLOUDS
Drives: 2010 2SS/RS
Well again I dint have my tunes or logs with me, but I believe I was looking at stock c6 tunes and noticed the shift times were zeroed out there as well. Again I'm going off the top of my head. But with them zeroed out I was logging .1 second shifts. Ill post it up so you can look through it tomorrow.
.1 sec shifts are very impressive. I've only been able to see .200. Are you running any TM?
11.39 @ 118 510 DA
Old 01-06-2010, 08:29 AM   #12
rodimus prime
Drives: Cargo van.
My 2-3 was hitting .1, I think everything else was .2-3. I also noticed that all my factory 1-2 2-3 3-4 upshifts were already set at .0 from the factory.
So looking at the shift patterns for d/s /tutd
You have different patterns for them that pretty much changes the shift pressures for the trans at different temps and torque amounts. From the factory the camaro uses the same pressure for d/s and a different pattern for tutd, which when you open the tables the pressures are identical in all but one box, so thats a moot thing to change in the end, unless you want to make two distinct transmission feels for your car.
As far as my tm settings, the only tm I have on is "power downshift" "garage shift" and "neutral down skip".
I did just catch a few things going through my tune that I need to tweak that I didnt know about on my first go around with the trans.
Old 01-06-2010, 08:45 AM   #13
rodimus prime
Drives: Cargo van.
Apparently there is another beta out that has more trans controls. Im going to stick it out with this one until the offical os comes out, seeing as I cant really beat on my car anyways in the cold. Theres not much I could do to tell if I like it or not.
Manual shift - 1-4 ? calflan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 01-19-2015 10:39 PM
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 08:25 PM
Auto Tranny Shift Too Much? King Mouse 5th Gen Camaro SS LS LT General Discussions 26 05-23-2009 02:45 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 09:28 AM
