Old 08-21-2020, 02:56 PM   #1
Little Walter
Drives: ZL1
305/35ZR20 Goodyear Eagle F1 G:2
If anyone is interested Speedytire.com have the rear Gen 5 OEM ZL1 tires for a super price of $127.50 right and left.
Little Walter is offline   Reply With Quote
Old 08-21-2020, 03:44 PM   #2
Z/28Dan
Z/28Dan's Avatar
Drives: 2023 1SS 1LE Vivid Orange
Damn.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 08-21-2020, 04:40 PM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Bet that Date Code is pretty old..
ZMEnow is offline   Reply With Quote
Old 08-21-2020, 10:22 PM   #4
Little Walter
Drives: ZL1
The set I got are dated December 2019, is that considered old?
Old 08-21-2020, 10:26 PM   #5
ZMEnow
No you are lucky, every set I have seen online at giveaway prices when I call the dates are 4 plus years.
Old 08-21-2020, 10:34 PM   #6
Little Walter
Drives: ZL1
I have never payed any attention to date codes until you mentioned it today, I actually had to call the goodyear tire store for them to tell me what numbers to give them. They said that this was good and anything that had been stored properly even three or four years old would be good, is that your understanding also?
Old 08-22-2020, 12:40 AM   #7
ZMEnow
I had this conversation with Goodyear engineers about 6 years ago regarding high performance tires that would be used at high speed consistent 100 mph buzzing and hard cornering. Of course they have to say you should not use beyond date code. Then off the record we discussed typical signs of any sidewall cracking as a sure reason to not run the tire in any performance criteria. I store mine in a basement at 70 degrees with controlled humidity, and no source of UV light. The UV light is the biggest destroyer of the compound. Excessive dryness will along with any UV source will begin to break the resins down. If you can be assured the tire has been in the environment described above then you can exceed the date code. If you cannot then inspect both the inner and outer sidewall for possible dry rot and limit use to getting ice cream and cruising. Now some will say they don’t worry about date codes.. Ever wonder why you see so many RV trailers pulled to the side of the road during the summer. Exposed to sun all year and the owners only go by mile use not date code and dry rot.
In summary if it’s only a couple of years old you will be good. The limit for putting never used tires in service is 6 years.
Old 08-22-2020, 11:36 AM   #8
rvnmaniac
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300
Damn they want over a $100 to ship 2 tires..
rvnmaniac is offline   Reply With Quote
Old 08-22-2020, 11:50 AM   #9
Dega Man
Drives: ZL1
I jumped on these, my shipping to Alabama was $37.70 for the two.
Dega Man is offline   Reply With Quote
Old 08-22-2020, 11:53 AM   #10
rvnmaniac
I would have jumped on that shipping price.. I even tried 2 different addresses. One in Md and one in Del.
Old 08-22-2020, 12:01 PM   #11
Dega Man
Drives: ZL1
Yea you lost all of any saving with the shipping cost, it's hard to believe that it would cost $100.00 to you and only $37.70 to me both being on or so close the east coast. I just hope the ones I get are as recent date code as the one's little walter got.
Old 08-24-2020, 10:48 AM   #12
rvnmaniac
My thinking is that you may be closer to one of their distribution centers.
Old 08-24-2020, 11:54 AM   #13
ChuckZL1
Drives: Chevy Camaro ZL-1
$127 to Ship to Phoenix. Not worth it.
ChuckZL1 is offline   Reply With Quote
Old 08-24-2020, 12:22 PM   #14
MichiganMatt
Drives: 2013 ZL1 Convertible
I got a ~$50 quote from speedy tire to ship to Detroit, two tires. I also looked at Amazon, $150 each w/ free shipping. I guess a couple of places with lower prices now...
MichiganMatt is offline   Reply With Quote
