Old 12-27-2009, 12:56 PM   #1
2fine69
Drives: 2010 2SS
Positive Offset/ Backspacing
Does anyone have max. backspacing measurement (positive offset measurement) on rear of 2SS? I know 305 is the max on factory wheel, but is there enough space behind wheel to add additional backspacing to the wheel to accomodate larger tire? My car is ordered, and I really want to order wheels before it gets here, If you have this info, please help!
I just have to believe theres gotta be some space left to fill!
2fine69 is offline   Reply With Quote
Old 12-27-2009, 02:24 PM   #2
75rusty
awesome!
Drives: 07 Jetta WB, '92 GTI 16vT, '76 LUV
Pretty sure 305 is max width period, may want to search. The guys I've seen pictures of running 305's on stock wheels had them widened.
75rusty is offline   Reply With Quote
Old 12-28-2009, 09:14 AM   #3
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
The 2010 Camaro can easily fit an 11.0" wide rear wheel and a 315 tire. Custom forged wheels typically take between 5-10 weeks to build depending on brand, so plan accordingly. I'd be glad to assist when you are ready, the brands I carry are in my signature below.
Tony
Fquick.com/NineBall
Old 12-28-2009, 09:46 AM   #4
chevyss
SS/RS
Drives: 2010 SS/RS IOM w/blk stripes A6
Does anyone know the back space on the stock wheels? I'm working to get a new set of wheels and the wheel company needs to know the stock BS. Thanks in advance
chevyss is offline   Reply With Quote
Old 12-28-2009, 10:13 AM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
I just have to believe theirs gotta be some space left to fill!
Hope this helps you, This is from the Forge line Web site with the numbers off my car. http://www.forgeline.com/wheel_fitment.php
all for the rear.
Front spacing = 100 MM
Rear spacing = 235 MM
Caliper clearance =40 MM This you need to check (GM changed the brake pad)
Caliper height = 215 MM This you need to check (GM changed the brake pad)
Hub diameter = 67 MM
Hub height = 12 MM
Old 05-19-2010, 06:37 PM   #6
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Resurrecting an old thread here. Does anyone know for sure if you take a stock SS 20x9 wheel and widen the inside of it 1" making it a 20x10, is there enough clearance in the inner fender well, suspension components, etc. to do this with a 305/35/20 P Zero mounted ?? How about if the car is lowered 1" with lowering springs ( no aftermarket coil overs ) ?? My measurements with stock springs/ride height look like there is plenty of clearance to do this. But I may go for 1" lowering springs in the future. It appears a 10" wide rim is sufficient for a 305/35/20 Pirelli P Zero as some folks have already mounted this tire on a 9" rim but I'll listen to the tire experts if I'm wrong. I do not want to run wheel spacers and I like the look of the stock Midnight Silver wheels.
TIA...Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-20-2010, 09:20 AM   #7
Nine Ball
Nine Ball's Avatar
Ed,
Most widening companies prefer to go 2" or more on the hoop reweld process. Adding just another inch puts those two weld beads very close to each other. Most of the Camaro guys here simply put the 9" rear wheel up front and widen the front 8" wheel to 10" and put it on the back. Either way, spacers are needed to make them fit properly.
I hate spacers.
Fquick.com/NineBall
Old 05-20-2010, 12:40 PM   #8
nuptualnemesis
NuptualNemesis
nuptualnemesis's Avatar
Drives: Silver 1SS M6 - 480hp 11.57/120.79
I test fit an after market Z06 18X10.5 rear rim with a 8.04" back space and a +58 mm offset. It appeared if the tire was any wider than the rim the back would rub. It would probably rub in any event with squat on launch. The caliper also needed a 1/8 or 1/4' spacer not to rub on the front of the caliper. Some people say they run these without a spacer. Maybe a different brand would fit a little different.
The Z06 18x9.5 front rims have a 7.38" backspacing and +54mm offset which should provide enough back space but I don't know if a spacer would be necessary to clear the front of the calipers. http://speedwaymotors.com has the cheapest aluminum billet spacers.
Offset is from the outer part of the lug stud hole to the center of the rim either plus or minus. Positive offset moves the center of the rim toward the inside. More positive offset will move the back of the rim toward the inside of the car. (tire rub)
Backspace is distance from Inside of lug stud hole to rear of rim. Less back space less chance of rubbing inside of tire.
You also have to consider if a rim is center ecentric or lug centric. 2010 camaro has a centering ring on the inside of the rim that fits over the axle hub to center the wheel. The Z06 rim is also center ecentric and has a different size centering diameter/hub diameter. This centering is lost with a spacer, although a 1/8" spacer may be OK if the hub diameter is the same. Most people with spacers are using the bevel on the lug nut to center the rim.
I have 20x10 OZ rims with a +45mm offset and 7.28 back spacing that work great.
nuptualnemesis is offline   Reply With Quote
2010 Camaro PRODUCT SAFETY RECALL: Positive Battery Cable Rerouting mcernik Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 171 01-08-2011 03:09 AM
Offset question Maro99 Wheels and Tires Talk Sponsored by The Tire Rack 4 12-10-2009 01:08 PM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 05:20 PM
Aftermarket wheel compatibility CamaroSkooter Wheels and Tires Talk Sponsored by The Tire Rack 19 04-03-2009 06:41 PM
Wheel offset of stock wheels? jc211 Wheels and Tires Talk Sponsored by The Tire Rack 0 03-27-2009 02:54 PM
