Old 01-07-2010, 11:06 AM   #1
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
V6 auto differential swap to a SS,V6 manual?
I would prefer to have the LS3 with its limited slip and lower its gearing in my V6 auto. What would it require? I think it would be a possibe axle universal joint issue? Does anyone know ,rather then like me and guess?
PieNsky is offline   Reply With Quote
Old 01-07-2010, 11:32 AM   #2
mrray13
Drives: 2010 1LT RS Rally Yellow
I'm thinking of the same thing, but in the very minimum, going to the v6 manual rear end. Same size ring and pinon of the SS cars, with LSD. I'm not overly concerned about the ratio right now, although IIRC, the v6 manual is lower then the a6 cars as well.
mrray13 is offline   Reply With Quote
Old 01-07-2010, 11:38 AM   #3
PieNsky
PieNsky's Avatar
Yeah, that is why I put SS,V6 manual in the title. Ideally, I would like the LS3 however would go with the L99 or V6 manual as it seems they maybe the same. Anyway, I noticed a company that installed gears into the SS with a core change and if there was no core, a $750 dollar core charge would be made against their CC. I would pay that for a LS3 rear end.
Old 01-07-2010, 11:43 AM   #4
mjorgensen
HYPRVPR
Drives: 2008 Viper coupe
Not positive but most manual and auto cars now have different axle shafts for each based on the shock needs. Maybe the place doing the gear swap knows this and have it priced to reflect that. Have the dealer check and see if the part numbers match between the two.
M. Jorgensen
WMD
mjorgensen is offline   Reply With Quote
Old 02-16-2011, 08:27 PM   #5
buschow84
Drives: 2011 camaro v6 2lt rs manual
HELP!
i dunno where to ask but i own a 2011 camaro v6 manual talking with the dealership they said the differential size is the same as the v8s only the v6 auto is different, I want to throw a 410 gear into my v6 manual has anyone tried this or does it work they make the gear for the v8 and if the v6 manual is the same as that i will order a gear if it works good
buschow84 is offline   Reply With Quote
Old 02-16-2011, 08:55 PM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
You can put the V8 gears in the V6 M6 rear end. We have had several customers do it already with the 3.73s.
Standard vs Automatic MyCamaro5 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 153 07-25-2019 12:24 AM
Solo Performance V6 Mach-XL (Manual) and Mach-XLT (Auto) Exhaust Kits GOINGSOLO2 V6 Bolt-Ons & Tunes 13 07-13-2010 02:28 PM
Auto Transmission Impressions for V6? 67MellowYellow 5th Gen Camaro SS LS LT General Discussions 21 09-17-2009 08:35 AM
Automatic faster than the manual??? 2sharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 319 09-30-2008 10:20 AM
Camaro does the Nurburgring test track in 8:20 2sharp 5th Gen Camaro SS LS LT General Discussions 45 07-23-2008 04:17 PM
