Old 08-30-2021, 09:18 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Hero Rear tail lights, Do they work with LED Side Markers? I have heard yes and no.
Hi, I am going to be ordering Hero rear smoked Tail lights for my 14 2SS, I have hear that they work with LED side mark lights and I also heard they don't, I was planning on getting the Oracle smoked LED Marker lights. I do not want to use the Sequential function on the brake lights I want them to act like normal lights.
Anyone have any insight on this? I asked the vendor and he said they may act up and they may not. Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 09-16-2021, 08:54 AM   #2
Joe.G
Joe.G's Avatar
https://www.amazon.com/dp/B01M7RHH04...roduct_details
Received these today, hopefully everything works together.
Old 09-21-2021, 12:34 PM   #3
davesnever
davesnever's Avatar
Drives: mine
I know a lot of people have used these and had LED's burn out, save your stock filament housings and if I were you I would seal all the holes and seams with silicone for extra insurance.
davesnever is offline   Reply With Quote
Old 10-19-2021, 02:48 PM   #4
Joe.G
Joe.G's Avatar
No Issues with LED sides and Hero Tails, Only thing I don't like is the Delay between the Third brake light and the Heros, It's at least a second, I did put the Hero third on the flash pattern when it first turns on to try and take away from the delay.
Overall fit is nice, It curves in a bit more then stock where it meets the corner.
Old 11-27-2021, 10:17 AM   #5
Marknbacon
Drives: 2015 camaro SS
Oh wow. Glad to see I’m not the only one with that issue. It delays like an entire second and I’m paranoid about people not seeing when I put on my brakes.
What exactly did you do to help with the delay?
As for the OP’s question you shouldn’t have any issues with LED side markers with the hero tail lights. I have the clear/smoked ones and I really like them. I don’t think the side markers and tail lights share a circuit do they? Even if they did they’re just on/off, so it’ll just draw (a lot) less current.
Marknbacon is offline   Reply With Quote
Old 11-27-2021, 09:09 PM   #6
Joe.G
Joe.G's Avatar
Mark I am the OP, I have not figured anything out and I have done a lot of research, it appears some do it and some do not. I put my 3rd Brake light on a flash pattern and it kinda blends in.
Old 11-28-2021, 11:22 AM   #7
Marknbacon
Wow shows how much attention I actually pay to usernames and whatnot…
Gotcha. I’m not a huge fan of the flash pattern brake light but I may have to do that to at least get peoples attention before the regular brake lights come on. Seriously, super paranoid about someone not noticing that in slowing down and rear ending me.
Old 11-28-2021, 08:11 PM   #8
Joe.G
Joe.G's Avatar
I was not a fan of the Rapid flash wither, but I think due to the delay it kinda fits and helps.
