Old 01-08-2010, 02:05 PM   #1
Nicholas
Drives: 2010 Camaro 1SS/RS
Tire Pressure and Winter?
So last night I checked the tired pressure in my car and it was around 38 in the front and the back... well the Temp. dropped to about 19 degrees last night ... I check the tire pressure this morning... 35 front and around 28 and 29 in the back... so I'm wondering .. does the Cold Temperatures have anything to do with the tire pressure dropping like that? Comments please.. this has been bugging me all day... Thanks for reading this.
Nicholas is offline   Reply With Quote
Old 01-08-2010, 02:07 PM   #2
Ammo7
I GOT HER
Drives: 2010 Camaro 2ss/rs RJT
YES
Ammo7 is offline   Reply With Quote
Old 01-08-2010, 02:14 PM   #3
thecamaroguy
thecamaroguy's Avatar
Drives: 2020 ZLE 67 SS350
"For every 10 degree Fahrenheit change in outside temperature, your tire's inflation pressure will change by about 1 psi (up with higher and down with lower temperatures)"
http://www.tirerack.com/winter/tech/...jsp?techid=121
Thanks,
thecamaroguy
2010 Camaro 2SS - CGM
1967 Camaro SS350 - Baldwin Motion Tribute
2020 Camaro ZL1 1LE - White
Proud to say I have always owned a Camaro! A Camaro has been my Daily driver since I started driving!
thecamaroguy is offline   Reply With Quote
Old 01-08-2010, 02:21 PM   #4
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: was 2010 2LT RS 2G1FC1EV4A9103434
Yes, changes with temps. On my 20" Blizzaks:
In my garage the temp is about 35-40, tire pressure at start is usually around 34 psi, after commute to work (5o minutes, 32 miles) tires warm to 36-37 psi.
For the commute home & Camaro sitting in open parking lot at 20 degrees its around 32 psi and warms to 36-37 for the ride home.
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 - Traded-in 8/31/2019:
tjd24 is offline   Reply With Quote
Old 01-08-2010, 02:46 PM   #5
Nicholas
Ok thank all of you very much for anwering my question!
Old 01-08-2010, 02:49 PM   #6
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Your tire pressure dropped 9 PSI??? What was the temperature at the 38 PSI read- 100 degrees? That's a big drop.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 01-08-2010, 02:55 PM   #7
Nicholas
No it was like 64 degrees then went to 19 degrees but how the heck did it drop 9 PSI? thats whats been bugging me..
Old 01-08-2010, 02:56 PM   #8
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
on star also sends you tire pressure on there monthly letter
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 01-08-2010, 03:05 PM   #9
ravensjeff
ravensjeff's Avatar
That would bug me too. I keep my car in a heated garage at around 65 degrees. PSI = 36. On the way to work, might get 37/38 psi. With car sitting for 8 hours in 20-25 deg weather, it'll read about 34 psi.
You might want to check the pressure with a good gauge to verify the car readout.
Old 01-08-2010, 03:08 PM   #10
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I was thinking the same..... Sounds more like a sensor misreading ....
Use Nitrogen if your not now, your pressures will be more stable ...
Old 01-08-2010, 04:22 PM   #11
Nicholas
Thanks I'll check it when I get home... hopefully everything is ok.:bangdesk:
Old 01-08-2010, 06:49 PM   #12
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
Somtimes very cold temps can cause a tire to leak air in addition to the cold induced reduction in pressure. Happens all the time here in MN.
Camaro_Custom_Painted is offline   Reply With Quote
Old 01-08-2010, 06:51 PM   #13
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
PV = nRT
Ideal gas law
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 01-08-2010, 11:00 PM   #14
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Shrinkage factor...
...cold causes it to get smaller - the tire pressure of course.
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Winter Tire TPS's AKcamaro Wheels and Tires Talk Sponsored by The Tire Rack 2 12-17-2009 05:52 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Driving an LT/RS in Winter without tire modifications mernst23 5th Gen Camaro SS LS LT General Discussions 23 09-18-2009 11:42 PM
Tire pressure for Heritage Wheels 1998 Brickyard Wheels and Tires Talk Sponsored by The Tire Rack 5 09-14-2009 08:42 PM
Tire Pressure Monitoring Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 8 08-14-2009 07:42 AM
