Old 10-16-2021, 05:15 PM   #1
concrete jungle
Hitman
Drives: 2012 Camaro SS
2012 Camaro SS Camshaft position sensor location?
I have a 2012 Camaro SS with the L99 engine. with 70k miles. On a 300 mile trip I noticed it was taking longer to start than normal and the code P0340 popped up. I bought a new camshaft sensor per the code but can't find out where it goes.
*A lot of the pictures that came up when I googled it showed the crankshaft position sensor location, not the camshaft sensor location.
concrete jungle is offline   Reply With Quote
Old 10-16-2021, 07:46 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Try this, see post # 12... Good luck..
https://www.camaro5.com/forums/showthread.php?t=408456
Old 10-16-2021, 08:07 PM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Look behind the crank pulley on the right hand side. You will see it and the connector for the cable that leads to the wiring harness. It’s a nightmare to get to with everything on the car.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 10-17-2021, 01:39 PM   #4
concrete jungle
Hitman
Thanks guys!
https://youtu.be/dc-rY9J51_M
Old 10-17-2021, 07:18 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Welcome... Hope ya get it fixed..
Old 10-17-2021, 09:29 PM   #6
concrete jungle
Hitman
Got it fixed, took a couple hours.
I could do it again in 30-45mins.
* 1.Start with bottom plug on bracket and unplug
2. remove bottom bracket bolt
3. remove top bracket bolt
4. unplug camshaft senor
5. push bracket down and out of the way
6. remove camshaft senor
* camshaft sensor is hard to get out, I turned in back and forth and then got on it with plyers and pulled/wiggled straight out.
Old 10-18-2021, 04:33 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Youza brother!!!! Awesome to hear...
