Old 03-08-2022, 01:33 AM   #1
rvender
rvender's Avatar
Drives: 2010 ss/rs
Is it safe to break in new 416 on old tune?
Motor was ls3 with btr stg4/headers/no cats and tuned. New motor is 416/ cnc heads/ custom grind cam/ 3.91’s. Is it safe to break in in on the old tune before it gets flogged on the dyno?
Thanks in advance!
rvender is offline   Reply With Quote
Old 03-08-2022, 07:02 AM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I’ve also got a BTR4/long tubes/bolt ons tune that I’ll be breaking my 379 in with. My tuner said it’s fine to get some heat cycles in (and make sure I have it all back together correctly!) with the old tune, but no WOT or anything. My engine builder that put the bottom end together said 50 miles for break in, so I’ll probably get like ten in after initial fire up, but the rest will be during the drivability and dyno tuning.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 03-09-2022, 12:18 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
Thanks in advance!
Depends on the quality of the tune but if you did not change injectors or cold air kit you should be fine.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-06-2022, 03:02 AM   #4
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD
or major changes in compression ratio
ZL1C7 is offline   Reply With Quote
