Old 04-22-2022, 10:50 AM   #1
JoeB
Drives: 2010 Camaro SS
TSP VVT1.2 Cam Change - I have bent intake valves?
So, I'm just now getting everything buttoned up. It's been taking a while because of addressing other disasters around my home. I've been trying to build a garage all winter long, and a dump truck knocked over a large concrete block wall. Now tied up with building inpsectors, insurance, etc.
Remember me? The guy that didn't check the head gasket part numbers (recieved LS1 instead of LS3) from Texas Speed in my DOD/AFM delete with VVT1.2 cam kit. See link here: https://www.camaro5.com/forums/showt...=602395&page=4
And now drum roll please,...I have bent the intake valves on #1 and #3 cylinder after trying to fire up for the 1st time. #5 and #7 are visually ok as I pulled the driver side head. I did a leak test on #2 and it is bent. Will need to pull that head too.
I don't know what has happened, but I haven't yet pulled the timing chain off of the single bolt TSP 1.2VVT cam to see if dowel pin sheared??? I have just pulled the driver's side head at this point. Yes, I lined up the cam at 6 o'clock and crankshaft at 12 o'clock. I remember taking pains trying to line up those marks. But obviously I've made a mistake somewhere.
(Tried to start it once, and it sounded like an old small block chevy 180 degrees out of phase, so I immediately stopped)
JoeB is offline   Reply With Quote
Old 04-22-2022, 11:11 AM   #2
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Was a cam phaser limiter block installed in your phaser gear ?
Did you have a start up tune ?
I could be wrong but when I did my vvt stage 3 for my truck my tuner told me not to start it at all until he gives me a start up tune ..
I take it you never verified if the dowel pin from the cam was in the notch In the back of the phaser gear ?
Risingson05 is offline   Reply With Quote
Old 04-22-2022, 11:33 AM   #3
Rmkuper
Rmkuper's Avatar
This would be the most logical explanation. Verify: 1) the phaser was installed 2) it was installed in the correct position 3) it was installed correctly. If the tension on the phaser was comprised or the retainer screws were not repositioned correctly it could cause PVC.
With that said L99 pistons have an indentation in them to avoid PVC its pretty difficult unless something is really off like timing, incorrect rods. Etc....
No offense but you did swap the dod lifters and replaced factory pushrods right?
Sent from my SM-F916U using Tapatalk
Rmkuper is offline   Reply With Quote
Old 04-22-2022, 12:51 PM   #4
JoeB
1. Phaser installed per TSP instructions.
2. Dowel Pin appeared to have engaged cam sprocket in assembly, but difficult to tell. Will verify as I disassemble.
3. TSP indicated only DOD need be turned off, it was.
Old 04-22-2022, 12:53 PM   #5
JoeB
All lifters replaced with TSP parts. DoD delete kit. Phaser installed per TSP instructions. Actually Comp Cam part.
Old 04-22-2022, 06:43 PM   #6
Risingson05
Drives: 2015 zl1 m6
When you open the door the phaser gear to install the limiter block there was one screw that you wer suppose to leave intact - I only know this as I undid it and hear a spring let go and had to buy another phaser gear .
The bolt you leave intact you just loosen to swing the phaser gear door open
Old 04-23-2022, 02:18 PM   #7
JoeB
It's my goof! Looks like the cam dowel did not engage the timing chain gear. This is a trick to install it appears. Any advice appreciated. Back of Cam Gear. See dimple. Looks like about 60 degrees off. That would do it!
Does anyone know how far the dowel on the VVT1.2 Texas Speed Cam should protrude into the gear? Below are my measurements of the dowel pin length protruding from the face of the cam.
GM cam = .180"
TSP cam = .100" (I may have shoved the dowel further into the cam during the faulty install,..it did not mushroom) See the picture where I'm measuring with the calipers.
Old 04-23-2022, 03:10 PM   #8
Risingson05
Drives: 2015 zl1 m6
Glad you found it !! That dowel looks alittle compressed if it were me , I’d go ahead and buy a new cam - peace of mind thing
I painted the dowel with red finger nail polish and just like how it left an indentation on the back of the gear is how I knew which direction to rotate it . Then by repeat to get it closer and then in the hole
Old 04-24-2022, 08:10 AM   #9
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Are you the Guy that posted on Garage Journal about the stone truck taking out rear wall?
Glad you found your issue.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-24-2022, 03:13 PM   #10
JoeB
Unhappy
Unfortunately yes (I also enjoy that website). So you could say it’s been a challenging spring to say the least. However, this problem wasn’t the dump truck driver fault. All my doings here.
You just gotta smile & keep living.
Have a good Sunday!
Joe
Old 04-24-2022, 04:59 PM   #11
JoeB
Are the lighter LS3 valves by GM the valves of choice? Looks like all intake valves are bent after I checked them. Exhaust valves are fine.
I see Manley valves & Melling are other choices.
Old 04-24-2022, 07:36 PM   #12
Joe.G
Joe.G's Avatar
Yeah I'v been on that board for years, I have read your post there since Thursday, I'll catch up tonight. Sorry to hear that and good luck with your car.
