Old 05-03-2022, 08:19 PM   #1
Arkangel-77
Arkangel-77's Avatar
Drives: 2010 SS Camaro
Drivers Side AC warm - 2010 SS, not climate contoll car?
I am confused.
I have a 2010 SS and the AC is blowing Ice Cold on the passenger side but kinda warm on the drivers side. The Heater works on Both sides just fine. Thing is I don't have dual climate control in this car? Any thoughts on what could be causing this? If it was the Blend door the temperature would not change right? Any thoughts on what could cause this?
Thanks, Cory C
Husband and Father
Arkangel-77 is offline   Reply With Quote
Old 05-03-2022, 08:58 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
From another thread. More like than likely, the blend door.
AC warm from driver vents, cold from passenger vents.
0stones0 is offline   Reply With Quote
Old 05-03-2022, 09:58 PM   #3
Arkangel-77
so the blend door dose cause different temperatures from drivers to passengers hu? boooo that =(
Husband and Father
Old 05-03-2022, 11:12 PM   #4
Arkangel-77
is there a way to verify that its the blend door?
Like I read about clamping the hose or something?
Husband and Father
Old 05-04-2022, 07:35 AM   #5
0stones0
It don’t come easy.
0stones0's Avatar
Here’s a database of threads about this problem, I threw together. Should be something in there to help you.
Heater Blend Door Datbase
Old 05-04-2022, 07:55 AM   #6
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
I am confused.
Thanks, Cory C
A system that's low on refrigerant will do that. Check that first!
NOT A 45 is offline   Reply With Quote
Old 05-04-2022, 07:59 AM   #7
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
You can lay on your back and look up at the door. It's pretty obvious if the door is broke or not. But as already posted there is no need to do that because a broke door is the cause for what you are describing, there is nothing else that can cause it.
Old 05-04-2022, 09:19 AM   #8
NOT A 45
NOT A 45's Avatar
Yep, your right, that's the only thing that can cause that. The engineer who wrote this in the service manual probably never read all the bad advice in this forum!
Does the discharge air temperature between the right and left center instrument panel outlets vary by more than 1–2°C (2–3°F)?
—Go to Step 7
7
The A/C system may be undercharged.
Leak test A/C system. Refer to Leak Testing.
Recharge the A/C system to specifications. Refer to Refrigerant Recovery and Recharging.
Old 05-04-2022, 10:05 AM   #9
gtstorey
Do any steps say to check if the blend door is broke?
Old 05-04-2022, 11:20 AM   #10
hudson773
Drives: 2014 camaro SS
—Go to Step 7
7
there are a lot of good facts on this forum, and a lot of rumor based opinions. thanks for doing your homework.
hudson773 is offline   Reply With Quote
Old 05-04-2022, 11:28 AM   #11
NOT A 45
NOT A 45's Avatar
No there isn't. That wasn't my point. He said the blend door is the only thing that can cause his condition, and that's not true. I've wasted a lot of time and lost a lot of money by assuming the most common and not checking the basics first. Kinda like diagnosing a transmission problem without first checking the fluid level......same thing here.
Old 05-04-2022, 02:40 PM   #12
NOT A 45
NOT A 45's Avatar
It's not homework, it's doing this day in and day out for 39 years! You are correct, there are a lot of good facts and experiences with the guys on this forum. Problem is too many people on here assume because their car had a similar problem and needed this or that to fix it then that's for sure what the problem is with the other guys car! To me that's just bad advice...to me properly it should be "my car did something like that and this fixed it so I'd check that" Great example is the 17 Suburban sitting behind me. No a/c.....so 90% of these always have a leaking condenser. Instead of just assuming, I leak tested the system and it turned out to be the line to the rear a/c in front of the right rear tire leaking. Kinda hard to sell that guy that repair after selling him a condenser he didn't need huh?
Old 05-04-2022, 03:11 PM   #13
Arkangel-77
Thanks for the replies guys. I spoke with the Local dealership today and they also said it might be low on refrigerant. They serviced the AC last years and they said system was perfect so if its low ... Guess they missed something? I have an appointment to bring it into them for diagnosis next week.
On A brighter note - I went threw my paperwork and my 48 month 50000 mile warranty still has 3 Months left on it! AC is for sure covered. SO fingers crossed whatever it is - it is covered by the warranty!!!
IMO - Blend door seems a bit iffy. I can go from hot to cold and it works, Its very strange that one side is warm verses the other wen the Max AC is on. Sounds like low refrigerant might be a more plausible explanation?
Thanks again - I will know more next week.
Cory C
Husband and Father
Old 05-04-2022, 03:49 PM   #14
NOT A 45
NOT A 45's Avatar
Cory C
Exactly why I recommended checking the refrigerant first.
