Old 05-19-2022, 08:55 PM   #1
GMCHRIS98
Drives: Chevrolet Camaro
Camaro 2014 1ss
I have a 2014 camaro 1ss that recently just started to throw ac only on the driverside and passenger just blows like if the ac is off, and when put hot air both throw hot normally
GMCHRIS98 is offline   Reply With Quote
Old 05-19-2022, 09:39 PM   #2
redcoats1976
pinch off the heater hoses with vice grips and see if its the blend door.
redcoats1976 is online now   Reply With Quote
Old 05-19-2022, 10:22 PM   #3
GMCHRIS98
What happens when you pinch the heater hoses?
Old 05-20-2022, 08:31 AM   #4
redcoats1976
if your air blows cold from both sides its the dreaded blend door.you can read varous blend door threads for different ways to solve it.i think id be going for a valve to turn off the hot water to the heater core if it happened to me.
Old 05-20-2022, 08:36 AM   #5
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
It's probably low on refrigerant. I would check that first! The blend door either blocks off the opening to the evaporator core, or it blocks the opening of the heater core, or when not in full hot or full cold mixes the two. When it's broken it mixes the two resulting in warm air all the time. So I doubt that's your issue but anytime someone complains of a hvac problem everyone on this forum immediately assumes its a broken blend door.
NOT A 45 is offline   Reply With Quote
Old 05-20-2022, 01:07 PM   #6
Royal Tiger
Drives: 2013 2SS/RS Convertible
I have a new issue for you that I’d love your opinion on.
When on vent even turned all the way cold I get warm air no matter the outside temperature, but my a/c blows nice and cold from both sides no issue.
Royal Tiger is offline   Reply With Quote
Old 05-20-2022, 01:50 PM   #7
gtstorey
Cabin air filter completely blocked not letting outside air in?
Old 05-20-2022, 02:16 PM   #8
NOT A 45
NOT A 45's Avatar
Guess that's possible or maybe but unlikely the seal is deteriorated on the blend door? I have one apart right now changing the door, and I'm looking at it trying to figure how that condition can happen. Just to elaborate on something I said many posts ago about GM changing vendors for this door, I compared the replacement door with the original and although they look exactly the same as for construction, and reinforcement.....the old one is a dull plastic whereas the new one is shiny. Obviously a different material.
Old 05-20-2022, 02:50 PM   #9
Royal Tiger
I had my blend door replaced 2-3 years ago.
Where is the cabin filter?
Old 05-20-2022, 03:12 PM   #10
GMCHRIS98
So you think it can just need refrigerant? It blows cold but only on the driverside and not the passenger side, and when I turn on the heater it blows hot on both sides & I noticed when I flip the heater on with the ac button on it continues to blows cold until I remove the ac button it starts throwing in the warm air. But today im gonna go get some freon and try the hose clamp thing as well
Old 05-20-2022, 03:17 PM   #11
gtstorey
Accessed through the cowl if I remember correctly.
Old 05-20-2022, 03:35 PM   #12
redcoats1976
i hope they changed it before 2015,already had to put in an evaporator core last summer...
Old 05-20-2022, 07:30 PM   #13
ssonic2013
ssonic2013's Avatar
Drives: 2013 Camaro ss
I'm glad I bought a extended warranty.with today's prices it pays for it's self pretty quick. if you plan on keeping your car
ssonic2013 is offline   Reply With Quote
Old 05-21-2022, 01:42 AM   #14
joekono
joekono's Avatar
Drives: Camaro Convertible 2014 1LT
Here ya go buddy!!!
joekono is offline   Reply With Quote
a/c, air conditioner
