Old 01-13-2010, 06:49 PM   #1
redsap05
Drives: 2005 pontiac gto
recipe for 500rwhp cam only
Well in the spring I will have my SS and I like many of you want the famed 500rwhp. After spening countless hours surfing the net I believe I put together a proven recipe to be 500rwhp cam only meaning no other interal engine mods. We are going to be putting this same setup on a friends car sometime this month so I will post back with dyno numbers. First off you must have a m6 for this to work right as far as making the number but an auto will be find it will just read lower.
Lets start with the main component AKA the cam. When the Ls3 fist came out it was thought that you needed a wide split. Lately this has proven to be a internet myth. In surfing the net I have found tons of reasearch on corvetteforum.com not surprising seeing as how they have had this engine for 2 years now. For starters you need to call comp cams directly and order this cam, its not an off the shelf grind and therefor must be custom ground.
Tell them these exact specs.
230 intake on a xfi lobe 612 lift
234 exhaust on a xer lobe 598 lift
114 lsa with 2 degrees advance so 114+2 Lsa
For more reasearch on the above cam this thread is a very good read.
http://forums.corvetteforum.com/c6-t...right-now.html
Also you will need the following
Full exhaust, 1 7/8ths long tubes and catback. Btw texas speed has a great deal on the whole system
A very good cold air intake, the vararam is looking promising.
It wouldn't hurt to have your stock Ls3 manifold ported, fasterproms.net has a great program for this.
Thats it along with a professional dyno tune this package should make 480-505 rwhp and 430-460 rwtrq. If anyone else trys it post up your numbers. Everyone has different opinion when it comes to things like this and cams. This cam is proven in the corvette world and has great drivibility, no bucking/surgeing and performs at the track and on the dyno.
redsap05 is offline   Reply With Quote
Old 01-13-2010, 07:04 PM   #2
themossman
Apprehensive Optimist
themossman's Avatar
Drives: '10 SS/RS SIM
I have the following cam:
Vengeance Racing Stage III LS3/L92 Camshaft 231/243 .617/.624 115+3
you can see the result in my sig (dyno'd in the HOT southern summer) and details in my build journal.
Add upgraded springs and hardened pushrods to your list....
Car is for sale --->http://www.camaro5.com/forums/showthread.php?t=158486
Current Summary:
Engine:Phase One-(All work by Vengeance Racing): Custom Cam, AR Headers, ported throttle body, ported intake, custom tune, dual valve springs, hardened push rods, under drive pulley, thermostat, Vararam CAI, C5R timing chain, Melling oil pump catch can, breather, MagnaFlow Sport Axle Back
Suspension: Pfadt Sport Sway Bars, Pfadt drop springs
Other: MGW Shifter, Custom Paint
my build journal ---->http://camaro5.com/forums/showthread.php?t=30057
themossman is offline   Reply With Quote
Old 01-13-2010, 07:05 PM   #3
g-townmach
I FARTED
Drives: 2010 2SS/RS
Theres a bunch of off the shelf cams out there that will get you 450-480 rwhp easy. Can't go wrong with custom grinds though. Your #'s look like a great steet cam with a nasty side. I'm a big believer in 114 LSA. Keeps it smooooth.
g-townmach is offline   Reply With Quote
Old 01-13-2010, 07:13 PM   #4
FTI-EDC
The stick man
FTI-EDC's Avatar
Drives: 2004 GTO - C5 'vert - SRX
This should get good....
PONY WARS
FTI-EDC is offline   Reply With Quote
Old 01-13-2010, 07:53 PM   #5
redsap05
Yea there are lots of great cams out there and they get you to cetain place and all go about it different ways. This is what me and my friends are doing. Everyone isn't going to do what we do and thats good. Iam not looking to start a cam pissing match here. Just shareing stuff I have found and or learned. Thats it. Nothing more. So before this turns in a cam debate everyone know thats not my intention. I wish everyone the best of luck with their builds.
Old 01-13-2010, 11:20 PM   #6
66DeuceLS1
66DeuceLS1's Avatar
Drives: 2010 2SS/RS SIM M6 Hockey Kit
Dude - thanks for posting this data....I had read this cam about a month ago and could not find where I read it at. You saved me some head scratch-en for sure! I was impressed on the results from a number of different people that had used this pattern. Now I just need to get up the courage to install one and accept the fact I will void my warranty! :(
2SS/RS SIM M6 Polished 20's, Hockey Strips,
GFX, Kooks LT's, High flow CATS, Magnaflow x-pipe, Vararam CAI
66DeuceLS1 is offline   Reply With Quote
Old 01-13-2010, 11:40 PM   #7
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Deuce....I'm right with ya..I'm gonna do it...it's real easy..just squeeze the trigger nice and easy....you can do it...
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 01-14-2010, 04:12 PM   #8
redsap05
Cool! Your welcome and thats exactly why I posted this. With the mods you have I would think you would at least hit 480rwhp. May want to think about getting your intake manifold ported as well. Keep us updated.
Old 01-14-2010, 11:26 PM   #9
Sam88gta1
Drives: 2010 Camaro SS / 2006 CC Duramax
You will have a hard time making anything near 500rwhp with this small cam in a Camaro. Making that power in a C6 is far easier.
Sam88gta1 is offline   Reply With Quote
Old 01-15-2010, 12:27 AM   #10
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
When you get this cam in can you post some video and dyno results, this looks like a cam I might go with, thanks.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 01-15-2010, 01:54 AM   #11
leviticus88
Camaro Owner Soon!
Drives: Chevrolet Cobalt SS/SC S2 GMPP
Care to explain?
leviticus88 is offline   Reply With Quote
Old 01-15-2010, 07:21 AM   #12
FTI-EDC
The stick man
FTI-EDC's Avatar
Originally Posted by leviticus88 View Post
Care to explain?
It's not possible with the criteria noted. Pretty simple.
Unless you have a dyno operator that tweaks the correction factor to give you a *number* you want.
PONY WARS
Old 01-15-2010, 03:12 PM   #13
Jason 98 TA
Drives: Camaro
I'll agree 1000% with Ed.
I've spent enough time developing & testing camshafts for the LS3 engines. 500 honest rwhp with a cam only setup just isn't going to happen. Checkout our site, we have several camshafts with engine dyno data for you guys to look at.
Custom grind camshafts are not always better. People like to say that, but most of the time people selecting the "custom grind" camshafts have very little experience with camshaft development & testing.
After 100s of hours & several hundred dyno pulls testing LS3 camshafts I'd put our line of camshafts up against any of the supposed cam guru's grinds....
Jason 98 TA is offline   Reply With Quote
Old 01-15-2010, 03:31 PM   #14
themossman
themossman's Avatar
I was trying to politely tell him that by sharing my results....
Current Summary:
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 05:36 AM
Help me find a Cam want you? jpsuperman81 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-31-2009 01:37 AM
