Old 06-30-2022, 08:20 PM   #1
anthony303
anthony303's Avatar
Drives: 2010 Camaro SS red
15 Camaro SS key won't come out of ignition
When I put car in park key sometimes won't go back and release unless I hit automatic shifter toward frt of car then key will release out of ignition... is that maybe a adjustment under shifter? And how to or is it a new ignition switch? Thanks John
anthony303 is offline   Reply With Quote
Old 07-01-2022, 07:50 AM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Very common. There are many threads on here about it, just look around
joshnmn is offline   Reply With Quote
Old 10-14-2022, 02:54 PM   #3
phoenix78
phoenix78's Avatar
Drives: 2014 Camaro 1SS (A6 Ashen Gray)
I encountered this issue. For me, I disconnected the solenoid that holds the key in place. Can't recall the specific process, but I know that it was easy, quick (15-30 minutes), and didn't require me to order any parts. I haven't noticed any issues as a result of the change.
If you do this, make sure that nobody ever pulls out your key while driving. It'll supposedly lock the steering wheel in place.
Relevant forum post: https://www.camaro5.com/forums/showthread.php?t=567161
Edit: Here is a video that shows the process:
The process, as shown in the video (in case the video disappears):
  1. Adjust steering wheel position (there's an adjustment lever underneath the wheel) so that it's pulled completely towards the driver, and as far up as possible. Lock the wheel in this new position.
  2. Remove the three 7mm bolts that are on the bottom side of the steering column(?). You'll see some indentations/holes where they're each located.
  3. Pop the steering column open. There appears to be three sections (bottom left, bottom right, top center). In the video, the guy specifically pops the left bottom section away from the right half, eventually completely removing it. He then separates the right bottom section from the top center section (he had to work the hole in the bottom right section over/past the key to remove the section).
  4. On the right side, without the cover that you removed, there's a little yellow box just past the keyhole. There's a plug that you disconnect from the yellow box. The plug has a tiny lever that you push, which allows you to disconnect the plug.
  5. Your key should now be able to be removed. Reassemble everything that you took apart.
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Anvil Auto carbon fiber notch spoiler, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
phoenix78 is offline   Reply With Quote
Old 10-14-2022, 03:58 PM   #4
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
I’ve had my shifter replaced once under warranty for this problem and it has started happening again. There are several potential workarounds and fixes, but I thought this was the best explanation and potential fix for the issue:
https://youtu.be/sETuCmaTLhY
For now, I’ve been doing the following if the key gets stuck:
1) Turn key back to “on” position (don’t need to start the car)
2) Place foot on brake (car can stay in Park)
3) Squeeze the silver shift release button at the top of the shifter several times rapidly
4) Key should be able to be released at this point
If this ever stops working, I will probably try the procedure in the video.
Originally posted this comment here: https://www.camaro5.com/forums/showthread.php?t=609182
KenKat is offline   Reply With Quote
Old 07-22-2023, 09:14 PM   #5
Ck1984
Drives: 2015 camaro LFX V6
good to know for near future reference, mine is doing same thing
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 07-29-2023, 12:19 PM   #6
ccbryson6161
Drives: 2014 Camaro 2SS
Key stuck in ignition
So I researched the crap out of this. Installed a new ignition switch and didn't work. Found a useful video the take apart the shifter trim to get to the shifter switch.
https://www.google.com/search?q=cama...id:59kfjhXDF0Q
Problem for me was the damn 25cent Chinese shifter switch is bad. I searched all over and can't find a replacement switch and it does not have a part number. As you can see I jumped the 2 wires but I don't like rigging things like this, especially when I give this car to my daughter. Started happening around 40,000 miles. Key comes out all the time but issue is you can be in any gear and remove the key. Only good thing is once in park and key is removed shifter stays in park. Was anyone able to find this piece of crap switch? Only other option is to spend $165+ for the entire shifter but a buddy of mine did that and 2,000 miles later he had the same problem.
ccbryson6161 is offline   Reply With Quote
Old 07-30-2023, 08:30 AM   #7
bsn
Drives: 2013 ZL1
Thats called a limit switch/micro switch you will probably have to modify one depending how it mounts. Don't worry about AC or DC ratings just amps.
https://www.amazon.com/MXRS-Hinge-Mo...ps%2C97&sr=8-4
https://www.amazon.com/dp/B07P4CJ8TV...1-df67fc737124
bsn is offline   Reply With Quote
