Old 07-02-2022, 03:04 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
A/C fan issue
Just started having an odd issue the other day. A/C fan speed will randomly increase/decrease. It's almost like you grab the fan speed control and mess with it periodically. Has nothing to do with engine speed. No changes in cooling, so I doubt anything to do with blend door. I'm thinking first to pull the covers off the controls and clean the electrical connections, but wanted to see if anyone has experienced the same.
SS_Dave is offline   Reply With Quote
Old 07-02-2022, 03:18 PM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It's usually a sign the fan motor is going bad and will need replacing soon. It's located right above the glove box.
Old 07-03-2022, 05:48 PM   #3
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Haven’t had it in my Camaro, but several other vehicles I’ve had with similar symptoms have been fixed by changing the blower motor resistor…..generally up under passengers foot well behind glove box
EMB135Driver is offline   Reply With Quote
Old 07-03-2022, 08:04 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Yup. The fan motor resistor, not the fan, should be the first thing to investigate.
Rock-It Man is offline   Reply With Quote
Old 05-07-2025, 07:26 PM   #5
Ssx_jake
Drives: 2010 Camaro ss
2010 Camaro ss blower fan not working
I replaced the blower fan the blower resistor check the fuses and the blower motor is still not working. What do I need to check next? Please someone help 2010 Camaro SS
Ssx_jake is offline   Reply With Quote
Old 05-08-2025, 12:50 PM   #6
Ernie70
Ernie70's Avatar
Drives: 2010 Synergy Green Camaro 1LT
It can also be dirty contacts in the rotary fan knob. That would be the easiest start to trouble shoot. Take apart , use a lil contact cleaner with a toothbrush , reassemble. That was what we found with a friend of mine's 2010.
Ernie70 is offline   Reply With Quote
Old 05-08-2025, 05:30 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ This. I saw a video on YT about this issue, they hd to take the AC/Radio head unit out to get to the back of the control knobs to remove them and clean the contacts. Worked great after that. the contacts are under the dials, and that's the only way to clean them, the dials are attached via a small screw from the back. Here you go, found it. Good luck!
https://www.camaro5.com/forums/showthread.php?t=621069
