Old 09-03-2022, 05:31 PM   #1
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
Low tire pressure light on.
Anyone run into this situation on their Z.
Took it out for a drive this morning and TPMS warning light came on.
Front looks good, rear driver looks good, rear passenger got a blank reading.
I checked the tire pressure and it’s good. I clear the reading and it rings wanting me the tire is low. I also cleared and reset the tire learning mode.
Still pressure is at blank with ringing warning. I think the TPMS sensor is out on the rear passenger side.
Any inputs where and how to go about this. If I take it to dealer they will say it’s a special car so it’s got a special high price. I’ve dealt with this special car, high price stuff before, like all fluid changes. It cost nothing but they keep saying it’s a special car. I know Z is a special car but don’t need special price. You know what I mean.
Inputs. Thanks.
Current Cars:
2008 Honda CRV 2.0L
2015 Chevy Z/28 7.0L
2016 Chevy Tahoe 5.3L
Past Cars:
1976 Chevy Malibu Classic 5.7L
1985 Chevy 2DR 4x4 Blazer 5.7L
1989 Chevy IROC-Z 5.7L
1995 Chevy 2DR 4x4 Tahoe 5.7L
2005 Chevy 4DR Tahoe 5.3L
pzero is offline   Reply With Quote
Old 09-03-2022, 05:57 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Inputs. Thanks.
Think your assumption is correct. Take it to a tire shop and have it replaced there.
0stones0 is offline   Reply With Quote
Old 09-03-2022, 07:27 PM   #3
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
Inputs. Thanks.
Pretty sure it’s the tpms on that corner. If it were low it have a reading.
BUT, the problem is to fix it the wheel must come off. Which requires that person not to damage your rotor upon R&R(removal/reinstallation). Then the person to remove the tire to instal new tpms must not scratch your wheel.
So the tpms is not special but it takes special care not to F up your rotor and wheel.
Long shot but try deflating then inflating tire to see if it’ll get it working but even if it works it’s on its last leg.
SIM GhostrdrZ is offline   Reply With Quote
Old 09-03-2022, 10:31 PM   #4
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Tpms has low battery,it can also checked with scantool.
Old 09-04-2022, 02:31 AM   #5
ariZona28
Give speed a chance
ariZona28's Avatar
Definitely looks like the TPMS battery died. Not sure what the lifespan is but after 7 years this is what we're going to be running into. I had mine replaced on my 2LS when I got new skins last month. If one is bad you can probably expect the others to be ready to check out. When it comes to tire stuff I put the car up on jacks, remove the wheels and bring them to Discount. Yeah, they can still booger up the rims but at least the extremely expensive rotors are safe.
ariZona28 is offline   Reply With Quote
Old 09-04-2022, 10:22 PM   #6
The SS Godfather
The SS Godfather's Avatar
Drives: TBS BLOWN/CAMMED 2010 CAMARO RS/SS
I have the same, tried the reset , checked pressure was all normal, so i forget about it !! i put air in my baby every 6th trip out all round anyway as heat, speed ETC loose PSI anyway , so no issue my friend!!
The SS Godfather is offline   Reply With Quote
Old 09-07-2022, 04:59 PM   #7
_Chigga
Drives: 2015 Z/28, #225 Red
I've got the same exact problem on the same exact sensor, I left it on the back burner for weeks, just ordered a sensor from the dealer. Was going to install it next time I bring the Z to work for an State Inspection
_Chigga is offline   Reply With Quote
Old 09-07-2022, 06:00 PM   #8
pzero
pzero's Avatar
You wouldn’t have the AC delco part number?
Current Cars:
2008 Honda CRV 2.0L
Past Cars:
Old 09-07-2022, 08:27 PM   #9
Gbland60
Gbland60's Avatar
Drives: 2015 z28 Black w/ac #645
Here ya go
Gbland60 is offline   Reply With Quote
Old 09-07-2022, 08:28 PM   #10
Gbland60
Gbland60's Avatar
Get the grey ones
Old 09-07-2022, 08:29 PM   #11
Gbland60
Gbland60's Avatar
Summit is where I got mine
Old 09-07-2022, 09:09 PM   #12
pzero
pzero's Avatar
Thanks dude! Went to AC delco and they had like 6 different kinds for Z/28. Sheesh, sure wish they just stuck with one kind on all Camaros. At least they should separate boys to men (v6 to v8).
Current Cars:
2008 Honda CRV 2.0L
Past Cars:
Old 09-08-2022, 02:58 PM   #13
Gbland60
Gbland60's Avatar
Ha Ha Ha.
No problem man
Old 09-08-2022, 04:08 PM   #14
CamayroZ
Drives: '15 Z/28
FWIW: TPMS batteries are good for ~6+/-1 year. Each have 2 gyrometer inside them to sense L/R side/direction and to put the unit to "sleep" to save the battery or the opposite and "wake it" when you start rolling.
If you can help it, purchase the "freshies". Get as new a date code as you can.
CamayroZ is offline   Reply With Quote
