![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Chime in
Anyone have BMR 1.4 lowering springs with after market struts/shocks? I have BMR's right now with my 1Le suspension, and it's time to upgrade. Rebound is sketchy driving over dips, and it bottoms out if I go over a decent size bump.
Looking at Pedders Sport Ryders/ Koni Orange. Or if you have lowering springs and any aftermarket strut/shock. How's the ride? Rebound? Bumps on highway? Don't want to do coilovers.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I have the ZL1 Eibach® - 0.5" x 0.3" Pro-Kit Front and Rear Lowering Coil
Springs (https://www.phastekperformance.com/E...-38144.140.htm). I currently have the rears in with Bilstein shocks but don't have the fronts in because the front Bilstein's aren't available right now. And let me tell you it doubled the stiffness of the rear end almost to the point of too stiff compared to the original SS set. But I have no idea how stiff the 1LE is compared to my stock set up or the new set up. You're probably thinking why did I go with ZL1 springs? That was all based on the drop because the ZL1 springs had the least amount of drop (1/2" for the ZL1 compared with the 1" drop on the SS springs) and I didn't even want to drop it at all but that is the least amount I could find.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
why don't you want coilovers?
Budget constraints... already dropped 16k on a new engine... I can do Megan CO, which supposedly are BCs.... but I already have the springs. Don't really care for adjustability. Also cheaper to swap a shock or strut if 1 of them does blow out.
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Bilstein was the answer for my lowered 1LE. The BMR springs on the stock suspension were a mismatch and made for a rough ride. As soon as I swapped to the Bilsteins with the same lowering springs the ride improved. It's really what should have been on the car originally.
#6 | |
#7 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
im interested in these responses as well. My 2010 isnt a 1LE but i also have the BMR springs and im thinking to improve the ride, it might be time for struts/shocks
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads 2006 Dodge Magnum RT "The daily" |
#8 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
I have the Koni yellows. I got them from a vendor on here on sale for only a few bucks more than the oranges. Been great so far. Very nice ride.
#9 |
Arogg my brother, I’m thinking of going this route soon, depending on my cage build. I already ordered the seats and harnesses. You can have my Koni Yellows. They have probably 10k on them tops.
#10 |
My next hurdle now is if my 315 rear tires and my 295 front tires will clear the suspension. They say OE fit, but of course geometry can be different.
#11 |
Sounds good man! let me know. PM me when ur ready!
#12 |
Ok we’ll figure it out. I just ordered these on Tuesday.
#13 |
Same for my lowered SS. I am also happy with my Bilstein B6. They are the right stiffness for me. I have 1.25 springs. I abuse them pretty hard on track days. They also have lifetime warranty. After 5 years one rear started leaking it is on way back to them now. They have not approved the warranty yet, but I do expect them to. I like the simplicity of the B6's vs coilovers Off Topic: RupertPupkin what is your lower front splitter? My ACS has gotten dinged up Like the idea of running a lower splitter. -Chris |
#14 | |
ZL1 addons https://zl1addons.com/products/camar...SABEgL5a_D_BwE
