Old 10-25-2022, 09:47 AM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Question Magnuson Supercharger: LS3 Magnum TVS2650 Order update
Anyone know how Magnuson Production is going? Here is an update I got back at the beginning of October.
We have indeed been dealing with a brutal issue with the particular foundry on the Magnum for LS applications. We are finally seeing light at the end of the proverbial tunnel after making the painful decision to move our tooling to a new foundry. We anticipate to be able to start shipping some of our oldest backorders later this month and continuing to ship through the end of the year as many as we can get our hands on.
Thank you,
Magnuson Superchargers
Customer Support
Lnch Mny is offline   Reply With Quote
Old 10-28-2022, 12:07 AM   #2
Painterdave81
Drives: Chevrolet Camaro
maggie 2650 order
i ordered one in August from boost district still nothing
Painterdave81 is offline   Reply With Quote
Old 10-28-2022, 01:17 AM   #3
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
Me and lunch money have been waiting since may. Condition of the new world we live in. Hence the new foundry.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 10-28-2022, 09:10 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
dang, that stinks. At least they are responding to you and providing insight.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 10-28-2022, 11:49 PM   #5
Painterdave81
i ordered full kit. but id like to source all the parts i need
for third belt drive any ideas on who to buy from. i know
i need ac bracket power steering idler etc.
Old 10-29-2022, 06:20 PM   #6
Scotty D
Drives: 2014 1le 1SS CRMT
Lsa convection. Com
Scotty D is offline   Reply With Quote
Old 10-31-2022, 06:57 AM   #7
rpol78
Drives: 69 Camaro Pace Car
If you want a factory look GM sells the full accessory drive kit. You may want to check with Magnuson to see if the unit you purchased will work with the LSA pulley spacing. A few years back I bought a TVS2300 kit for the camaro and the spacing was slightly off (i.e. 1 or 2 ribs) for the supercharger pulley to work with the LSA damper. You have to change the water pump too.
Basically all of the accessories are spaced out the same as the corvette and the third pully on the damper drives the SC. So your AC, power steering pump, alternator, water pump drive, tensioner and idler pulleys all need to move toward the block. The third pulley drive on the LSA damper is about in the same place as the accessory drive is on your current damper but is slightly off. If I remember correctly the additional 2 ribs are on the engine side of the damper SC pulley. So at least with the TVS2300 I would have had to find a pully that would clear the jack shaft mounting and had 2 inward additional ribs for an 8 rib SC drive belt to work.
Here's the base kit
https://paceperformance.com/i-625554...m-non-a-c.html
The a/c also has to move and here's the kit for that
https://paceperformance.com/i-625555...dd-on-kit.html
FWIW - The damper isn't included in the kits. I have a used GM damper I'd part with.
rpol78 is offline   Reply With Quote
Old 10-31-2022, 09:19 AM   #8
Ashen 6.2
Ashen 6.2's Avatar
Here is a link to the PDF File with part numbers and instructions for the older version of the GM Performance LSA Accessory drive kits - https://www.chevrolet.com/content/da...c-19243525.pdf
Old 10-31-2022, 11:28 PM   #9
Painterdave81
thanks guys appreciate the info
Old 11-14-2022, 02:38 PM   #10
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Got News that mine got pushed to December.
Old 12-02-2022, 03:25 PM   #11
Painterdave81
got my magnuson magnum today but only blower and heat exchanger. havent recieved hardware yet.
Old 12-16-2022, 09:58 AM   #12
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Great news everyone!
Well after 7 months of waiting we finally got the super charger. Hope to have it done by Christmas.
Old 12-16-2022, 10:04 AM   #13
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Glad you got yours! I've been told January now...
Old 12-16-2022, 07:14 PM   #14
Painterdave81
Im finishing mine up now You might look into boost district tensioner its a stout piece compared to stock one
