Old 11-22-2022, 11:03 PM   #1
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
ESS VS ECS
What would you go with , not so much head unit recommendations but over all quality of the kit
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 11-23-2022, 12:48 PM   #2
Silver2014SS
Silver2014SS's Avatar
Drives: 2014 Chevrolet Camaro SS
I have the ESS G2. Been running it for the last year and a half
Very impressed with the quality
I've heard great things about the ECS too. Might be a little more expensive? But I don't think you can go wrong either way
2014 Camaro 2SS - GPI SS2 cam, ESS G2 blower 8 psi 105/160mm, ID1050x, DSX Aux Kit, Kooks Longtubes, hi-flo cats, Borla S-Type catback, BMR trailing arms and OTR bushings, McLeod RXT twin-disc, 3.73 ZL1 diff and ZL1 axles, Innovate Motorsports ECB-1 gauge
733 rwhp/603 rwtq
Silver2014SS is offline   Reply With Quote
Old 11-23-2022, 02:43 PM   #3
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
I'm happy with my ecs kit, the only thing I wish I did was get the tuners kit cause my goals have changed and I need to upgrade the fuel pump and injectors.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 11-23-2022, 09:05 PM   #4
davidscamaro
That's good to hear , qualify is pretty important to me , dont want to buy a kit twice , or have to upgrade half the parts
Old 11-23-2022, 09:07 PM   #5
davidscamaro
I see the ecs tuner kit says 17 to 19psi with no restrictor,
That max ? or with the pully it ships with ? There web site did not even have pully information
Old 11-23-2022, 10:56 PM   #6
RupertPupkin
Drives: 2014 Camaro SS 1Le
I've been happy with my ecs... both good units.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 11-24-2022, 07:36 PM   #7
gsxrturbo
Drives: 2010 ss
I Have mine ecs 1500 no restrictor with cam headers.with the 3.47 pulley i am at 14 to 15 psi.if that helps.thing pulls really hard
gsxrturbo is offline   Reply With Quote
Old 11-27-2022, 11:30 PM   #8
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
ESS G3X here. Super nice kit, makes tons of power. Very happy with the kit. Hardest part is explaining to people that it is not a pro charger. I have seen 18 psi at 7200 on a missed shift. 95mm pulley. Sets at 16 psi at 7k shifts. Lots of that depend on supporting mods. I am in the process of upgrading to the G4-95 now. Building a 408 and 4l80 over the next few months. Easy bolt on to an N/A setup, just add a bigger fuel system.
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 11-28-2022, 05:28 PM   #9
Surfdog SS
Surfdog SS's Avatar
I am at 9# with the restrictor plate in the 1500 kit. You don't need to change pully just take out the plate if you want more boost. That's one of the reasons I went with it.
Old 11-29-2022, 10:52 AM   #10
eLeSthree
Drives: 2011 Camaro SS 6sp
I beat the shit out of the ESS Tuning kit. It never blinked. FYI, the ECS is 8 rib and the ESS is 10 rib. The belt routing of the ESS kit was designed for maximum contact/wrap around the pulleys. Plus being 10 rib, you will NOT be fightin belt slip like so many others do. I spun the G4-95 with a 207mm lower and 90mm upper to 7300 rpms. I havent done the math on impeller RPM, but lets just say most people wont be spinning it anywhere near that fast.
Another major difference is Intake Temperature. That is something most people dont think about until theyre shopping for a meth kit. I highly suggest trying out one of the ESS G2,3,4 head units. My intake temps were 108 degrees on the dyno making 1100+whp, just using E85 and the ESS Tuning intercooler.
ESS Tuning makes their own superchargers in house in Arizona. (although they do sell Vortech head units compatible with their kits). I believe they would stand by their product if anything ever happened.
ESS is completely exploding in the mustang world. F150 kits coming soon. They aren't going anywhere.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-29-2022, 12:57 PM   #11
RupertPupkin
That's 58k RPMs with 8" lower and 3.5" upper.. you had room
730whp: 630Trq
Old 11-29-2022, 09:28 PM   #12
eLeSthree
The G4 has a max of 72,000. So I guess I had plenty of room. Hence the low IATs.
1158whp 1017wtq.
630whp 658wtq
Old 11-30-2022, 10:27 AM   #13
JANNETTYRACING
JANNETTYRACING's Avatar
It really comes down to;
Power goal.
Desired Power curve.
How much future growth you want to leave on the table.
How you want the underhood to look.
Head unit options are also a consideration.
I sell both and can help you make a decision.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 11-30-2022, 11:18 PM   #14
davidscamaro
Power goal.
I want to go as far as a brand new ZL1 pump and quality BAP will get me in my 2010 SS
Stock clutch , car still under 18,000 miles tho
Dont care how under the hood looks
Power curve that works best in 1/4 mile drag racing with a driver that on stock clutch and trying not to break parts "soft launchs" on drag radials
Im FBO and cam right now , cam is Howard's racing 224/234 .612 lift 112+4 LSA , they clame it works great with small blower on there info sheet
