Old 12-09-2022, 04:12 PM   #1
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Need your help
Need some help guys. Are the lower control arm ends on the 5th gen liquid filled? I know the pics look like it can be antifreeze, but it’s not coolant. It’s an oily feeling substance. No signs of any leaks above, just what you see. The car has been undercoated and sprayed to hell with corrosion protection by the original owner I bought it from. Another though it may be some if that crap coming off with condensation? I appreciate your input. Thank you
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 12-09-2022, 04:19 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
There are bushings that are liquid filled. Not sure on the Camaro.
0stones0 is offline   Reply With Quote
Old 12-09-2022, 04:22 PM   #3
LT1Zob
LT1Zob's Avatar
So like everything else, if it’s leaking, it’s going bad safe to assume?
Old 12-09-2022, 04:27 PM   #4
0stones0
It don’t come easy.
0stones0's Avatar
If in fact that’s the issue. I’d check around for any other possible leaks, above and around it, as well.
Old 12-09-2022, 05:54 PM   #5
LT1Zob
LT1Zob's Avatar
Thanks. I don’t see anything else that may be the culprit. I just want to know for sure these are liquid filled before I order a new set. Absolutely no suspension noise or anything to lead me to believe I have an issue. Other than what looks like a leak.
Old 12-09-2022, 05:58 PM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Heres another thread on the subject.
Oil leak near front passenger wheel? Do bushings have oil?
Old 12-09-2022, 06:35 PM   #7
LT1Zob
LT1Zob's Avatar
Thank you Sir. That answers my question.
Old 12-09-2022, 10:11 PM   #8
Fish-man
Drives: too many to say!
Hey George, my 2nd one let go this fall
Fish-man is offline   Reply With Quote
