![]() Drives: Chevrolet Camaro 2LS Join Date: Dec 2022
Need Help on V6 LFX Engine
Hello forum,
I have a 2014 v6 camaro that's been overheating. I've changed the thermostat, the radiator fan, the coolant temperature sensor, water pump, and have flushed the radiator. Car has been 221° with no fan. Oil temp sensor has not shown temp with fan running fully. Shut the car off and cranked it back up. Temp reads again, but no fan. Any advice as to what the issue could be? |
![]() Drives: 2011 Camaro 2LT Join Date: Oct 2018
This thread mentions the relays you might want to check: https://www.camaro5.com/forums/showthread.php?t=500753
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
221 degrees is not overheating unless the cap has failed and it's not building pressure. The V8 fans don't cut on until over 220, upper 220's if I remember correctly.
I've checked all relays and I've checked power to fans. All are functioning properly. AC does not work and fans won't kick on at all. Car has always stayed at around 180°. Even at idle. It goes to 192 while driving and steadily rises at idle. Could it be a failed condenser or compressor for the AC? Could it be computer related?
What thermostat did you put in it?
#6 |
It was a duralast 180° thermostat
#7 |
Not sure what might be going on then. I would expect open highway driving to be around the thermostat setting this time of year. Unless you got a bad thermostat and it's actually a 190-195. Fans shouldn't be an issue since they shouldn't be needed while driving highway speed. 192 and rising while idling doesn't really sound like a problem.
I would start with an infrared temp gun and try to confirm the actual temps, if you can get so you can take a reading around the thermostat housing. Have you checked the radiator exterior for blockage? Maybe an airpocket in the cooling system? Other than the temperature reading, the computer doesn't really have any control over the engine coolant temp until it's time to cut the fan on, unless the V6 is a lot more advanced than I realize. A leaking head gasket can cause weird temperature readings. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Don't know about the LFX, But the LLT's Radiator caps don't last long
Check your Radiator Cap |
#9 |
![]() ![]() ![]() ![]() Drives: 2012 Victory Red LFX Join Date: Dec 2012
Since the 2LS doesn't have a gauge how did you determine it was running at 221 degrees?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
#10 | |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
I have heard about that issue and its a cheap solution/fix and worth a look.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
#11 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Both of my '15s have this display available on the DIC.
#12 |
did he ever figure out his heat problem?
2015 2LT LFX 3.6L
FE2 Sport Suspension MXO-6 Speed auto w/Tapshift Aftermarket Oval mufflers |
