Old 02-03-2023, 10:41 PM   #1
Bo White
Bo White's Avatar
CFD xmember flanges
CFD xmember flanges are installed finally!
Oil pan drops will be cake now 😉
Took it back apart to prime and paint. Let the primer cure overnight and paint tomorrow.
They take 7/16 bolts 1.5" long.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-04-2023, 10:16 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very nice work sir!!
Old 02-04-2023, 08:48 PM   #3
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Thinking of doing this. Would also need to find someone local to do a good job on the cut and weld.
SS_Dave is offline   Reply With Quote
Old 02-04-2023, 09:16 PM   #4
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Oh man, sooo much easier now
joshnmn is offline   Reply With Quote
Old 02-04-2023, 11:30 PM   #5
Bo White
Bo White's Avatar
Local muffler shop should be able to.
Totalled:
Old 02-05-2023, 06:14 AM   #6
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
nice Bo!
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 02-05-2023, 07:25 PM   #7
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Nice, I’m gonna do this to mine when I put the cam in it.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 02-10-2023, 03:07 AM   #8
bottletalk
Drives: 15 Camaro 2SS M6
are these flanges still available? that is a great idea and something I could definitely use!
bottletalk is offline   Reply With Quote
Old 02-10-2023, 05:05 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
It's still not as easy as you would think. Trying to get the oil cooler off the side of the pan is a task, getting the wiring harness under the pan off and back on is a pita, and you have to unbolt your rack and pinion from the subframe and push it forward on the 2010 to 2013 models (I'm not sure about the electric power steering models 14-15). And you'll more than likely to have to have it realigned after unless you have a good method for marking the rack and pinion but sometimes you get lucky. But it still beats the alternative. lol
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-10-2023, 10:08 PM   #10
bottletalk
Originally Posted by morepowerjoe View Post
IBut it still beats the alternative. lol
exactly hahaha
the alternative really sucks lol
Old 02-11-2023, 10:49 AM   #11
bsn
Drives: 2013 ZL1
The rack and pinion has nothing to do with alignment..
bsn is offline   Reply With Quote
Old 02-11-2023, 10:56 AM   #12
morepowerjoe
The hell it doesn't. When you unbolt it, it will move around on the subframe. Since the bolt holes are bigger then the bolts there self it's very hard to get it lined back up in the same place when you bolt back in. I know from experience because I've unbolted it to take the pan off 4 times and only got lucky once putting it back to where it was.
Old 02-11-2023, 05:07 PM   #13
bstromback2002
bstromback2002's Avatar
Drives: 2010 camaro ss
Didn’t have to touch my steering rack. Bought one of these from harbor freight unbolted the motor mounts and lifted the motor as high as I could. I got the oil pan out no problem after I cut the cross member.
bstromback2002 is offline   Reply With Quote
Old 02-11-2023, 05:24 PM   #14
morepowerjoe
Well good for you. There's apparently more then one way to do it.
