Old 04-20-2023, 05:13 PM   #1
redcoats1976
freaky drivers side window
when i open the drivers side door the window goes down almost an inch,whereas the passenger side only goes down a small amount.should i try reindexing the windows or is this something else?
Old 04-20-2023, 05:15 PM   #2
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Try indexing but has it always done that?
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 04-20-2023, 05:25 PM   #3
redcoats1976
no.i was involved in a pretty horriffic accident with a semi that required a new door,quarter panel,rear wheel and a few other bits and pieces.i just wonder if the body shop took the time to index the window,as other than that everything is perfect.this was last july but i just noticed it about a month ago.
Old 04-20-2023, 11:08 PM   #4
Wizard1183
Wizard1183's Avatar
You can do that yourself. Roll passenger down. Back up. Then driver side. But it should say you need to index and tells you what to do
Old 04-21-2023, 07:53 AM   #5
dkp2LT
dkp2LT's Avatar
Drives: '11 2SS, '11 C6 GS, '04 MDX
If you disconnect the battery for a bit, after you reconnect you should get the message that you need to re-index. You'll have to do both windows but it takes less than a minute.
dkp2LT is offline   Reply With Quote
Old 04-21-2023, 01:12 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And the other thing, when you hold the button to go down, at the bottom, hold the button for about a second or two, same when you go up, hold the button, then it should all be good.
Old 04-21-2023, 02:04 PM   #7
Ernie70
Ernie70's Avatar
Drives: 2010 Synergy Green Camaro 1LT
My passenger side did this for a while .. I tried the disconnect , the holdng the button down , and none of it worked . Then one day I got in it to leave for work , and it asked me to do the re-index. Then all fixed . So I don't know what happened ,other then one day it just decded to fix itself LOL.
Ernie70 is offline   Reply With Quote
Old 04-21-2023, 03:34 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well that's pretty funky!! But as we all know, sometimes our Camaros have a mind of their own!!
Old 04-21-2023, 04:50 PM   #9
gtstorey
Really have many minds of there own. I think the window regulators are their own modules, and I know there are modules in the doors.
Old 04-23-2023, 11:33 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, that's for sure!!
Old 04-23-2023, 01:03 PM   #11
redcoats1976
tried the battery disconnect,left it off for about half an hour...no result.still going down further than passengers window and the car did not request a reindexing.
Old 04-24-2023, 10:05 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hmm. The only other thing I can think of is maybe something slipped out of place in the window track where they fixed your door after the accident?
Old 04-24-2023, 01:48 PM   #13
ariZona28
Give speed a chance
ariZona28's Avatar
Probably this. If it's not demanding the indexing I would think that sensors, motors and other feedback items are in proper position. You may need to pull the door panel for a quick visual OR return to the trusted folks that performed the work and see what they say.
ariZona28 is offline   Reply With Quote
Old 04-24-2023, 02:09 PM   #14
Ernie70
Ernie70's Avatar
SO true bud! lol
