Old 01-20-2010, 06:56 PM   #1
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
Check this out
Has anyone tried these?
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
fieldgoal00 is offline   Reply With Quote
Old 01-20-2010, 07:02 PM   #2
Malice
Drives: 2022 Camaro 2SS 1LE M6
1) you can get that exact bolt/nut combo thingy from autozone for like $6.
2) Wierdo gas miser prius drivin' hippies put those on thier O2 sensors to decrease the amount of O2 the sensors see. This in turn dangerously leans out the engine in order get better gas mileage.
2022 2SS 1LE M6 - 100% factory stock
https://www.youtube.com/@GeoffPalmer83
Malice is offline   Reply With Quote
Old 01-20-2010, 07:06 PM   #3
BLK2SS
BLK2SS's Avatar
Drives: Black 2SS
They can also be used on the #2 sensors for a cat delete without tuning.
BLK2SS is offline   Reply With Quote
Old 01-04-2011, 02:06 PM   #4
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
Does anyone know if these work or if there are any negative effects to the motor?
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 01-04-2011, 02:28 PM   #5
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
It's post cat. It won't hurt anything.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-04-2011, 04:29 PM   #6
AC
***GO HOGS GO***
AC's Avatar
so I'm i correct to assume the #2 O2 sensors reading does not adjust anything in the motor as far as fuel air mixture? anybody, any help on this. i'm not up on all this computer stuff. thanks AC
Old 01-04-2011, 04:33 PM   #7
ssmike
BL1ZZRD
ssmike's Avatar
That's correct, no affect on a/f mixture, just compares #1 with what it should see at #2 and will throw a CEL code if out of tollerance. At least this is my understanding, no expert here!
Old 01-04-2011, 04:34 PM   #8
IndeedSS1
IndeedSS1's Avatar
This is correct. The #2, downstream, post cat, O2 sensors are only there to report on the health of the cats. Their readings make no adjustments to the AFR.
Dang that ssmike is a quick draw.lol
Old 01-04-2011, 09:10 PM   #9
Smoky10
Drives: 2010 Camaro 2SS
I installed long tubes on my car and installed a set of these since I removed the cats. They didn't do anything. Within two days I threw 2 CELs and they haven't gone out yet.
Smoky10 is offline   Reply With Quote
Old 01-04-2011, 09:50 PM   #10
IndeedSS1
IndeedSS1's Avatar
Plain old extensions work great in the SOLO highflow catted mid pipes.
Old 01-06-2011, 08:45 AM   #11
AC
***GO HOGS GO***
AC's Avatar
what are extensions? is this a spacer between the O2 sensor and pipe.
Old 01-06-2011, 08:53 AM   #12
AC
***GO HOGS GO***
AC's Avatar
Smoky10, how long ago did you install them?
Those with LT's, RESET your check engine light! TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 107 08-18-2010 02:51 AM
GM bulletin: HVAC system reprogram / rear spoiler repair / engine harness inspection Bonemaro Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 65 06-13-2010 06:41 AM
Is There A Better Way To Check Your Status besides VIZ? camaro19672010 5th Gen Camaro SS LS LT General Discussions 21 11-07-2009 08:36 PM
9/21 TPW Check In bono83 Camaro Price | Ordering | Tracking | Dealers Discussions 544 10-20-2009 10:52 PM
Check Engine Light 3GPa Tuning / Diagnostics -- engine and transmission 0 10-15-2009 11:02 PM
