Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
BMR Front and Rear Sway Bar and links
Getting installed this weekend, gotta do it myself, Mechanic wanted like $300 for the Install
![]() I got the Moog stabilizer links coming too plus some Superlube SUL41150 Only thing is, I got to do it with 4 Jack stands and a low profile floor jack. Anyone can give me some tips how to make it easier? I watched some videos but these guys are all pros lol. |
![]() Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
I did it on a c6 it can be done need the car to be higher but you do what you need to. PIA but you can do it. When I put peddlers on the camaro I paid for the install.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Front is the hard part. You have to come in from one side (I think I came in from drivers side) and twirl the thing around until you get it in place. Feel free to use a reciprocating saw on the old one to get it out.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
Life's just a Ride
Thanks guys, the saw is a great Idea but if I take the old one out, I will remember to put the new one in the same way lol.
You remove and install the front bar through the passenger side, just kinda twist/unscrew it out.
Orange Krush II
#6 | |
Life's just a Ride
Thank you Sir, I appreciated |
#7 |
From my build thread, maybe this helps:
"Front Sway Bar – this is a challenge, but not impossible to fish it out the Passenger Side. Now note that it is recommended that you remove the Engine Mount bolts and jack up the engine a few inches, BUT THIS IS IMPOSSIBLE WITH A WHIPPLE since there is only ~1/2” of clearance to the Dash. I found it actually can be fished out IF everything is already removed except the Tie Rod, as is my case with a total disassembly. Remove the (2) 13mm Saddle Nuts on both sides, pry off the saddles and old bushings first. Then articulate the Bar around the Power Steering Lines and once clear it is fished out the Passenger Side." https://www.camaro5.com/forums/showthread.php?t=442230 |
#8 | |
Life's just a Ride
#9 |
I think this is where I broke out the reciprocating saw. Despite being larger, I seem to recall the new one going in a lot easier than the old one coming out. Of course, I did not look for any information on it until I could not get the old one out.
#10 |
Life's just a Ride
I'm done, Yeah I had to get the 4 1/2" Grinder out too, The bushing and saddle would not come off
![]() Got the new one in, plus the links from MOOG, just raised the Engine up about an Inch, the rest was a piece of cake, just cork screw it in. Tomorrow the rear will go on, right now I'm pooped ![]() look at that pic it said LE 17 on the old one, is that what I think it is or just a rating? one question I got is, I heard about using the Rear Drop Down links instead of the Short stabilizer, anyone know what I gotta do or which part that would be? Thanks Guys. |
#11 |
![]() Drives: 2011 RS 2LT Join Date: Dec 2020
Nice job. Great info. I'm going to do this plus all new BMR suspension kit.
#12 |
Life's just a Ride
Cool 😎
I got these on the way. |
#13 |
Do you like the MOOG End Links front and back?
Thinking on buying them too. I need to save a little $$$. Thx |
