Old 12-06-2023, 08:26 AM   #1
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Catch Can Install
For the life of me I can't find the loop to disconnect to install my Catch Can
Did a search before this post but nothing. Since it's a manual it should just be one short loop right behind the TB, but I got this Custom Intake Manifold and 2 long rubber hoses are on where the loop should be, and they going towards the back. F@cking N00bs (me)
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 12-06-2023, 11:34 AM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
On a stock manifold its right at the manifold and TB, a port from the valley cover to the port next on the neck of the manifold. Which manifold do you have, or a picture would help. All you need on your custom manifold is a clean vacuum and use the dirty side to the valley plate.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 12-06-2023, 11:43 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And which CC did you get?
Old 12-06-2023, 11:44 AM   #4
NoDakZ/28
NoDakZ/28's Avatar
This also matters lol.
2014 1LE - Sold
Old 12-06-2023, 12:11 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
lol yep. That's why I asked. Mine is an RX with only 2 ports, one goes to my valley tray, and the other goes to the back of my LOD manifold.
Old 12-06-2023, 12:19 PM   #6
NoDakZ/28
NoDakZ/28's Avatar
Correct, any two port catch can should have the dirty side from valley or driver cover, and the clean side to a vacuum port on the intake manifold. Super simple
2014 1LE - Sold
Old 12-06-2023, 02:19 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome, I got that right! lol. When my tune shop installed the LOD for me, they had it backwards, I didn't think it looked correct, so I fixed it. I figured that's how it should be. My driver side valve cover is capped off.
Old 12-06-2023, 07:10 PM   #8
Infidel67
Life's just a Ride
Infidel67's Avatar
MightyMouse Mild Catch Can (2 Port) not the bypass ... Damn, I gotta rip the low profile manifold up for that?
Or can I just tie it in one of the hoses? (correct one of course)
Old 12-06-2023, 07:41 PM   #9
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
Where does the hoses connect to ? You mentioned they went towards the firewall? Might wanna show a pic ,so we have a better understanding where those hoses go to . Otherwise I mean you could always put a T fitting in to that existing hose but if it were me I’d definitely wanna know what that hose attaches to
I have a mm cc - wild and I’m tied to the sc port w/ valley plate capped off and tied to oil filler cap.
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
Old 12-06-2023, 07:55 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
On your can like Nodak and I have said, since it is a 2 port, the "in" port will connect to the tube coming out from the front of your valley tray, the the "out" port on your can will, like mine, go to somewhere on your intake manifold. Mine is connected to the back of the manifold for vacuum in one of the 3 holes that were there. So to start, since you don't have the "stock" manifold anymore, you will NOT have the loop tubing shown in the pic. Your valley hose should be one of the 2 hoses you speak about. Get a pic if you can and post it for us to help.
Old 12-06-2023, 11:25 PM   #11
Infidel67
Life's just a Ride
Infidel67's Avatar
Thanks Guys
Will make some Pics in the am...hell I can't get shit done right now, working 12-14 hours a day
Old 12-07-2023, 09:02 AM   #12
NoDakZ/28
NoDakZ/28's Avatar
Your can will be routed differently than the mild ls3 setup.
Thanks Guys
Please do so we can get you all straightened out. Run your can as stated from MM:
2014 1LE - Sold
Old 12-07-2023, 10:23 AM   #13
Infidel67
Life's just a Ride
Infidel67's Avatar
Here some Pics...hell I don't have a clue, I'm still a rookie learning.
Old 12-07-2023, 10:36 AM   #14
NoDakZ/28
NoDakZ/28's Avatar
Where do those lines go coming from the manifold? Also, where is the vacuum source going from your CAI?
Your manifold is should have its ports under and towards the rear.
2014 1LE - Sold
