Old 01-22-2010, 10:39 PM   #1
HaZe_X
HaZe_X's Avatar
Drives: Trailblazer SS & Camaro SS
1st oil change tomorrow, quick question
Might do my oil change tomorrow..Now I never owned a uni-body car..So jacking it up will be new.
As I understand it, I can place the jack front and middle (secure location), jack it up, place jack stands at appropriate spots on each side?
Or
Raise one side at a time?
http://www.sears.com/shc/s/p_10153_1...ord=jack+stand
HaZe_X is offline   Reply With Quote
Old 01-22-2010, 10:41 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Try Jiffy Lube... you'll be glad you did...
Old 01-22-2010, 10:42 PM   #3
HaZe_X
HaZe_X's Avatar
no way...
Old 01-22-2010, 10:44 PM   #4
jimmie.briseno
jimmie.briseno's Avatar
Drives: camaro
took mine to my chevy dealer and got the full synthetic. it was 70 bucks but it was worth the cash to save the time... in and out in 20 minutes... and they actually said i dont need another change for 5000 miles. most places still put it for 3000 even with full syn.
jimmie.briseno is offline   Reply With Quote
Old 01-22-2010, 10:45 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Then Raise one side at a time... much safer that way...
Old 01-22-2010, 10:49 PM   #6
adub4185
Drives: 2010 2SS RS, 2023 Camaro ZLE
Send a message via AIM to adub4185
check this thread out http://www.camaro5.com/forums/showthread.php?t=53422. has a bunch of info on the change itself and jack points.
Last edited by adub4185; 01-23-2010 at 02:29 PM. Reason: would help if i put the thread link in
adub4185 is offline   Reply With Quote
Old 01-22-2010, 11:26 PM   #7
Russell James
Russell James's Avatar
I use a floor jack under the front crossmember, and jackstands under the front subframe rails. I set it down on the jackstands and then pump the floor jack back up against the crossmember just for double insurance in case a jackstand slips or something. The crossmember is in front of the drain plug/oil pan, about in line with a straight line drawn between the center of the two front tires. There is a thin crossmember behind the drain plug - don't use that one, not strong enough.
On the rear, I've got a couple of bottle jacks I put under the frame sections of the rear subframe. If I'm by myself, I just pump each side a couple pumps at a time so it goes up fairly even.
Once the rear is up and the car is about level, I change the oil. If your floor jack is too tall to get under the crossmember or air dam. You can drive up onto some boards with the front tires before rolling the jack under. I use 2 x 12 sections I had laying around - put a 45 deg bevel on one end to drive up easy on to.
If the front wheels are not coming off, don't even need to use jackstands. Just jack it up and slide some ramps under the front tires.
I don't like driving up ramps, seen too many damaged cars from people trying that. But I'll jack it up and slide the ramps under the front tires and lower it down onto the ramps. Then just leave the jack under the crossmember with pressure against it for insurance.
Make sure you started and ran the car until warm before the change. Oil filters come off much easier when warm.
Old 01-24-2010, 01:02 PM   #8
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
.......... and they will let 3/4 of your oil drain and you get a cheap oil filter too boot.
P.S. -- I worked in one of those places while going to college.
FirstLSK is offline   Reply With Quote
Let's Talk About ZMax Oil Treatment a Moment. RCPW Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 60 02-13-2013 02:53 PM
Oil change based on oil life monitor? trm0002 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 46 10-19-2009 01:19 PM
1st Oil Change and 15mm! hamidar05 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 10-19-2009 07:13 AM
Early oil change...How do you know that you have reset the oil life system? Rob53 5th Gen Camaro SS LS LT General Discussions 6 08-23-2009 02:23 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
