Old 01-23-2010, 12:49 PM   #1
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Question Longer wheel studs needed.
To accomodate 'vette 18"x10.5" wheels with 315 drag slicks, 1/2" spacers look needed to get the clearance. The oem studs ain't long enough. Do any of you fellows know the stud specs, including the knurl diameter?
Ivas is offline   Reply With Quote
Old 02-04-2010, 08:37 PM   #2
Ivas
el Ruco
Wink Wheel stud size
The oem studs are 1/2"x 2.331" overall length. The knurl is .509. Jegs has 3.25" studs to press fit for spacer capacity; so does ARP. ARP are few bucks cheaper. Once swapped out, you'll need open ended lug nuts at 12mm-1.5 at 1/2 inch. Billet makes 'em as well as others.
CHANGING THE STEERING WHEEL (Not for the faint of heart) VT2CA Camaro DIY & HOW-TO instructions & discussions 28 09-19-2014 03:31 PM
Question: Cars only driven by one wheel? JMROD General Automotive + Other Cars Discussion 17 08-29-2010 05:04 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
Current wheel & design,just an observation nitrokid Wheels and Tires Talk Sponsored by The Tire Rack 5 07-25-2008 01:33 PM
