03-20-2024, 12:30 AM | #1 |
Drives: 2022 Camaro 2SS 1LE Join Date: Dec 2021
Adding shock sensor to factory alarm
Hi all, anyone attempt adding shock sensor to factory alarm? I an interested in adding DEI-504D. Anyone here have the factory wiring for the door trigger and factory alarm wiring?
03-20-2024, 02:59 PM | #2 |
Drives: Chevy Camaro 2019 Turbo 4 LT 6sp Join Date: Jun 2019
There's an easier way.
http://addshocksensor.com/shop-now.html Check there web site email them they send you an install video for you car and instruction plus a toll free tech support # They guarantee you will be able to install and set it up as close to plug and play as possible to work with your OEM car alarm and key fob. |
03-20-2024, 03:29 PM | #3 | |
Drives: 2024 Camaro 1SS M6 Join Date: Nov 2023
I'd be intrigued to try it if I could see an actual installation video. They seem to be deliberately obfuscating the install process other than telling you that you'll need wire cutters and maybe some crimpers... |
03-20-2024, 03:34 PM | #4 |
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
I imagine you only get an actual video after you buy the product. I understand why they wouldn't give away the install videos for free.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-20-2024, 03:43 PM | #5 |
2020 Shadow Gray 2SS
Drives: 2020 2SS - A10, NPP, MRC, CAI Join Date: Dec 2019
I contacted them, $155.00 for the system (free shipping), said it takes 40 minutes to install and claim they have never had anyone not be able to complete the installation successfully.
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
03-20-2024, 05:06 PM | #6 |
Drives: 70 GTX, 06 Mustang, 22 Camaro LT1 Join Date: Jan 2022
Likely you can take off the door panel, look at the latch mechanism and figure out the wire that grounds when the latch opens, then you'll know which color to look for in the kick panel. BTW you don't have to connect in at the door, you could go after the trunk or hood as well - might be easier to access dependent on your install.
I would bench test that sensor to ensure that it's output goes to ground when triggered. Or you'll have to add something that converts the output.
2022 CAMARO LT1 COUPE AT10
03-20-2024, 05:07 PM | #7 |
03-20-2024, 05:20 PM | #8 | |
I can tell you what you'll need to do... you will need source power and ground, and the output will Tee into your door sensor wire, likely in the driver kick panel. If they're quick thinkers, they'll just pop the hood and cut the horn wire or pull its fuse and continue the theft. One counter measure is better than none, but the more the better... they call that layering.
03-21-2024, 11:49 AM | #9 |
Thanks all for you answers and feedback!
03-24-2024, 05:09 PM | #10 | |
Drives: 2023 Camaro ZL1 Join Date: Jan 2023
2023 Camaro ZL1 6MT Summit White
03-24-2024, 10:21 PM | #11 |
Long hauler
I’ve definitely seen many cases where the thieves cut the horn through the grille or cut the grille to get to the horn, if it’s not too intrusive of an install I’d still like to get one of these. Too many times I’ve had a window broken into and the car alarm doesn’t go off, rather know it happens especially if it starts to rain through the night (actually close to happening once, thankfully caught it before the rain really started pouring)
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6 - Totaled Happiness: Infinite |
