Old 03-30-2024, 11:16 PM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Looking for rear subframe bushing washers/hats (takeoffs or part number)
I'm hoping someone out there has a set of these that they removed for solid bushings. I literally only need the washers that the bushings sit on. The bigger one is somewhat cone shaped.
Mine are damaged and while I would love to throw solid mounts on there, I just don't know when I'm going to be able to get it done. I can swap out the metal washers real quick for a quick fix for now.
I'm not finding these on any parts sites, unless it's considered part of the whole subframe, but that is showing discontinued.
terry_b is offline   Reply With Quote
Old 03-31-2024, 10:39 AM   #2
fz4k98
Drives: 2013 1ss
I had the same problem trying to find these. GM would not sell these seperately and I could only get them new if I purchased the entire subframe. Dealer suggested going to a salvage yard and see if they would sell them.
I took time and repaired and reshaped my old ones and reused them.
fz4k98 is offline   Reply With Quote
Old 04-01-2024, 06:23 PM   #3
terry_b
terry_b's Avatar
Yeah I'm afraid of this. I may reach out to hawk and see if they can get me a set for cheap, otherwise I may be forced to go the solid route...
At least one of mine is totally beyond repair, like the steel is basically crumb cake, and the others are not much better. I'll try to get a picture later just to show you the horror of it!
Old 04-02-2024, 07:58 AM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I suggest you install the solid mounts, with the right tools it is not a bad job.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 04-02-2024, 06:07 PM   #5
terry_b
terry_b's Avatar
Here's the horror show!
Old 04-07-2024, 01:13 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Here is what I have.
Old 04-07-2024, 08:12 PM   #7
terry_b
terry_b's Avatar
Those look much better than mine! I sent you a pm, if you don't need them anymore I'll happily take them!
