Old 04-05-2024, 03:02 AM   #1
kiteman
Drives: 2012 45th Camaro, 2SS/M6
lug nut missing
body work a couple years ago, I guess they never put it in on the passenger front. I don't drive much but moving 4 hours away in a month. should I get a new one? I moved across the country and let all my tools with my dad so I don't have a torque wrench or even know what the socket size is. should I run it without the one lug nut or go to the dealership or buy one and a torque wrench? and what is the size? like a 19mm? sorry it's been a while. thx for help
kiteman is offline   Reply With Quote
Old 04-05-2024, 03:12 AM   #2
MattMDR
Drives: 2014 2LS RRM
You should get one. Any auto supply store should have the right size. Take another as a sample. Don't worry about torquing it.
MattMDR is offline   Reply With Quote
Old 04-05-2024, 06:46 AM   #3
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
The socket size is 22mm.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 04-05-2024, 07:04 AM   #4
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
the thread size is 14mm x 1.5. That and the correct bevel are the most important things. If it were me, I would try to get an OEM replacement. Or maybe you can match it up from here
https://shop.advanceautoparts.com/fi...-wheel-lug-nut
Old 04-05-2024, 08:37 AM   #5
fz4k98
Drives: 2013 1ss
Take the time to check all of the lugnuts. One missing maybe a sign they all are suspect.
fz4k98 is offline   Reply With Quote
Old 04-05-2024, 03:08 PM   #6
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Sorry this is terrible advice. They definitely need to be torqued, especially for a multiple hour drive-even if it is just one lug. If not, you risk the wheel coming off, warped rotors etc.
if you don’t want to get a torque wrench buy the missing lug and take it to a tire shop or dealer, wouldn’t be surprised if they put it on for free.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 04-06-2024, 05:45 AM   #7
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Not being torqued might be the reason it is missing. I would get one & then check ALL of them.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 04-06-2024, 08:46 AM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
^^^This^^^
I've got so many extra Camaro Lug nuts... PM me your address and I'll send you one.
Old 04-07-2024, 12:01 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^This^^^
Yep, and if anyone else needs any stock lugs, I too have a bag full of them off my 2011 SS/RS.
Old 04-07-2024, 01:17 PM   #10
Rph74
Drives: 2010 Camaro 2SS
I could use those. PM sent!
Rph74 is offline   Reply With Quote
Old 04-08-2024, 04:43 PM   #11
acutron42
acutron42's Avatar
I also have a factory set if anyone needs them.
Old 04-08-2024, 07:16 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Replied...
Old 04-08-2024, 07:53 PM   #13
acutron42
acutron42's Avatar
Replied...
This is what this site is all about. Cheers
Old 04-09-2024, 10:28 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir! Couldn't agree more. Caring and sharing!! If I have something from my Camaro that I din't need anymore, and it's in good shape, and I see a need for it, you guys can have it.
