Old 05-16-2024, 07:28 PM   #1
fz4k98
Drives: 2013 1ss
whipple pulley question
I have a 2.9 whipple on a stock ls3 (has headers, cats, cai and tune) and run on 93 octane. The pulley is a 4 inch currently. i was wondering how much smaller pulley I can run on 93 octane and what kind of gain I might get by changing the pulley size?
fz4k98 is offline   Reply With Quote
Old 05-17-2024, 06:57 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
Gotta see if you have enough fuel pump and injectors, then maybe think of the pulley.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-20-2024, 02:57 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
In order to run any more boost you must upgrade the injectors, fuel pump and calibration.
I can help you with all of that.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-27-2024, 08:53 PM   #4
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Talking to Mike Malicoat @ Whipple, I was told several years ago that a good rule of thumb is about +25hp for every 1/8" of pulley diameter decrease.
If I recall correctly, I was tapped out on the fuel system around the 625rwhp mark.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 06-05-2024, 08:24 PM   #5
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
No fuel system will get you to ~625. Boost a pump extends that to maybe 725-750... MAYBE. It's all dependent on fuel, so do the big fuel system and only cry once, or do it in chunks and cry a lot along the way
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
