Old 05-29-2024, 03:18 PM   #1
jdarmon@rogers.com
Drives: 2014 Z28 BLACK 581 RWH
Daytime running lights
just purchased a 2015 z/28 from the US and brought home to Canada .Now i need to know how to turn on the DRL .Does anyone know
jdarmon@rogers.com is offline   Reply With Quote
Old 05-29-2024, 06:33 PM   #2
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
When you shift it out of park and the high and low beam headlamps are off the daytime running lamps will illuminate.
Mouse330 is offline   Reply With Quote
Old 05-29-2024, 07:40 PM   #3
macalot
macalot's Avatar
Drives: 1969 Z/28 + 2015 Z/28
There is no "park" in the Z/28.
You know you are having fun when you are getting 3.4 mpg !!
macalot is offline   Reply With Quote
Old 05-30-2024, 12:48 AM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
As far as I know the DRL (headlights) are always on when the switch is in "AUTO". But I'm always in the driver's seat.
ariZona28 is offline   Reply With Quote
Old 05-30-2024, 07:08 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Seems like Gen5DIY had a way to make them operate as fog lights instead of DRLs.
Old 05-30-2024, 07:42 AM   #6
jdarmon@rogers.com
The problem we have in Canada is that the DRL have to be all the time when the car is in gear and you cannot shut them off.The low beam light is fed a lower voltage for DRL .I have asked the local GM dealer and they are looking into I hope it is just a software change
Old 06-13-2024, 04:31 PM   #7
jdarmon@rogers.com
The local GM dealer used his scanner and turned on the drl and changed the spedo to KLM .$150
Old 06-13-2024, 05:38 PM   #8
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Once the e-brake is released and seated down the headlights come on in manual 5th gen cars, they act as the daytime running lights.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 06-14-2024, 08:37 PM   #9
macalot
macalot's Avatar
Pretty sure you got taken advantage of. In 'auto' setting the headlights act as DRL. Changing to kilometers, I don't know about.
