Old 06-27-2024, 12:31 PM   #1
phoenix78
phoenix78's Avatar
Drives: 2014 Camaro 1SS (A6 Ashen Gray)
Lightbulb Side Markers Review - Ruxifey vs ISC
I wanted to share a comparison of side markers from two different companies: RUXIFEY and ISC. I've had Ruxifey side markers for about one year. When 1-2 LEDs on a single rear side marker began to flicker or die (per some older Amazon reviews), I decided to try ISC's offering.
RUXIFEY is currently the much more affordable option at roughly $44 total via Amazon for two front and two rear side markers. In contrast, the ISC tinted side markers (part number ISC-1015SSM) via Phastek is on sale for $102. According to Phastek, their normal price for the ISC markers is $120.
Here's a photo of the ISC side marker, turned off, installed on my ashen gray Camaro. If you look closely, you'll see "DOT SAE" and "L" (to denote the left side of the car, I presume) on face of the product.
In this photo, the ISC markers are on the bottom with better hidden LEDs. Additionally, the LEDs look closer to a faint white in contrast to RUXIFEY's orange/yellow. The ISC markers have a black textured trim around the edge of the marker, whereas the RUXIFEYs appear to have a smooth plastic lens covering the entire face of the product. While I prefer the smooth face of the RUXIFEYs, I like how the ISC's LEDs aren't visibly orange up close. The plastic around the LEDs has a darker tint on the ISCs. Also, I noticed that the power plugs on the RUXIFEYs appeared to either have some corrosion or just dried soap/wax (I use a foam cannon to wash my car) when I uninstalled them.
Lit up, the RUXIFEYs -- on my passenger side -- glow into the black space around the LEDs.
In contrast, the ISCs -- on my drivers side -- show a bit of glow around the LEDs, but it's more focused and therefore looks sleeker in my opinion. My eyes might be playing tricks on me, but it also seems like the strip of LEDs is slightly longer than that of RUXIFEY.
In person, the LED brightness seems similar enough between both brands that I found no obvious difference. If my original side marker had not begun to flicker, I probably would not have spent the money on the ISCs. It was honestly tempting to buy a new rear pair of RUXIFEYs. That being said, I'm happy with the ISCs and do like how they look at night.
Mod list: GPI SS3 camshaft (VVT delete), ZL1 Fuel Pump, FIC 60 lb injectors, Tru-Cool 40k tranny cooler, Circle D 3600 triple disc (billet flexplate), GPI Rod Mod, Bo White ported TB, Variant Helium wheels, CAI cold air intake, Kooks 1 7/8" LTH w/ high flow cats, Ridetech HQ coilovers, BMR sway bars, BMR delrin subframe bushings, Hendrix offset poly diff bushings, Borla S-Type axle-back, Holley EFI Fuel Rails, Elite Engineering E2 catch can, Umbra LED Taillights, Anvil Auto carbon fiber notch spoiler, Kenwood DMX9707S head unit, some minor interior/exterior appearance mods.
phoenix78 is offline   Reply With Quote
Old 06-27-2024, 03:55 PM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I have the RUXIFEYs on mine and happy so far, been on for about 2 years. I don't like how the others how the DOT sae stand out. Thanks for the review.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 06-27-2024, 06:24 PM   #3
phoenix78
phoenix78's Avatar
Thank you!
The RUXIFEYs are definitely pretty solid for the price. To add to your point about the the "DOT SAE" lettering, there's also "L" and "R" on the ISCs to denote which side of the car they go on haha.
EDIT: Added the points about the lettering to the review.
Old 07-15-2024, 09:58 PM   #4
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
I've got these and they've had no issues so far.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
SS_Dave is offline   Reply With Quote
Old 07-17-2024, 04:45 PM   #5
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Thanks for sharing your review. I have the ghosted Oracle's on mine. The previous owner installed them not sure when and I have owned the car for about 7-8 years now. If they ever crap out then I will look into these.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 07-17-2024, 10:19 PM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
I have the same iJDMTOY, they have worked well.
Old 07-17-2024, 11:59 PM   #7
AlisoBob
Drives: Camaro 2SS Gen 5
These look so good..... I bought them twice.
At night, they look unreal good.
AlisoBob is offline   Reply With Quote
isc, led, review, ruxifey, side markers
