Old 09-02-2024, 08:12 PM   #1
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
New Brembo pads no pedal
Looking for some ideas before i take it to a shop. I recently changed my brake pads to new factory Brembo pads. Did the old school bleeding method first. RR LR RF LF with my wife operating the pedal. Took it out had no pedal, could hardly stop. Next i bought a compressor operated vacuum bleeder system, this time did it the way the manual says RR LF LR RF Ended up using the entire bottle of dot 3 fluid. Took it out with the same pedal feel. Checked the booster check valve and that’s working. So what’s next? Need some help.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 09-02-2024, 08:18 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Did you do the inner bleeders first and then outer? By no pedal feel do you mean the pedal went to the ground, or very solid pedal like no booster?
KillboyPowerhead is offline   Reply With Quote
Old 09-02-2024, 08:44 PM   #3
tartagliazl1
Yes inner then outer valve. Brakes don’t engage till the end of the pedal travel. Even then there is no bite to them. Very soft braking.
Old 09-02-2024, 08:48 PM   #4
tartagliazl1
One of the reasons why i thought i needed new pads were the pedal was getting longer before engagement. When i took them apart still had 50% pads left. Maybe i had a different issue all together.
Old 09-03-2024, 08:07 AM   #5
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Do you have a scanner capable of bleeding the ABS unit? Air shouldn't have gotten in there but there is a possibility and something I would definitely check. I would also even just for a street car step up to a Dot 4 Fluid ( this is not your pedal issue but something you should do ).
I go over board when I bleed brakes, But I would gravity bleed, then abs,Compressor and I always finish with the old school method but I do follow the manufactures rotation. I also use more than one bottle but my pedal is perfect in all of my vehicles.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 09-03-2024, 08:19 AM   #6
KillboyPowerhead
Drives: 2015 Z/22
If the pedal can travel fully to the floor then I'd suspect air in the system. If you let the reservoir go empty air could have been introduced and is now between the reservoir and ABS module, in which case you'd need to take to the dealer and have them bleed the brakes. Maybe check all four corners again and if there's no air anywhere I'd have it towed to a dealer.
Old 09-03-2024, 08:27 AM   #7
Joe.G
Joe.G's Avatar
Abs can be bled at home, Even cheaper Scanners now have this feature.You can buy a pretty decent scanner for less than the dealer will charge.
Old 09-03-2024, 09:21 AM   #8
KillboyPowerhead
Drives: 2015 Z/22
Ahh. Didn't know that us mere mortals were allowed to access brake/ABS modules. I believe such capability is purposely not allowed by HP Tuners and whatnot for safety purposes. I should see if my scanner can do this; recently put Brembos on the V6 but just bled/refilled with DOT3; planning to install the V8 master cylinder and fill with DOT4 but wasn't sure about the ABS bleeding.
Old 09-03-2024, 09:27 AM   #9
gtstorey
HPT has pretty much decided to stick with Drivetrain modules as a tuning software. They just don't touch anything else since you don't tune those modules.
gtstorey is online now   Reply With Quote
Old 09-03-2024, 09:58 AM   #10
tartagliazl1
I have the innova 3100 that does not do abs. It can read abs codes but won’t activate them.
Old 09-03-2024, 12:34 PM   #11
tartagliazl1
Just ordered the maxi check pro scanner with abs bleed. Let’s see if that works.
Old 09-03-2024, 02:47 PM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
There is a proper sequence according to the service manual and it's different than the traditional. Not saying this is why your pedal floors, just an FYI.
This might help too.
https://youtu.be/18vhMC--WE8?si=TCe0tScAATY4pIjS
FasNuf is offline   Reply With Quote
Old 09-03-2024, 04:05 PM   #13
tartagliazl1
Hey Mark, i did it by the service manual sequence.
Old 09-03-2024, 04:58 PM   #14
Joe.G
Joe.G's Avatar
You can try tapping the calipers with a rubber mallet while bleeding as well, air bulbs can be caught anywhere. I believe you changed a caliper as well and that's the one I'd focus on the most , did you run system/master dry by any chance?
