Old 09-28-2024, 01:52 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
NPP idea
Been thinking about getting a little louder with the exhaust. But, I also have zero desire for drone. Current setup is long tubes, high flow cats and stock mufflers on an LS3. It's fine, but i'd like it a bit louder and aggressive as it's rather mild till you really hammer it. So...
Thinking of swapping to NPP mufflers, but I'd need to do two things. Wire up switching and cut the quads and route through one tip. Reason is I have the GFX kit and I don't want to lose it.
So two questions: ANyone have an example where they've done this? And can you point me to decent switching mechanism to run the valves?
SS_Dave is offline   Reply With Quote
Old 09-28-2024, 01:53 PM   #2
SS_Dave
SS_Dave's Avatar
I did find this and am reading it now. May answer my q's. We'll see. Still curious about anyone who's done it keeping a GFX kit.
https://www.camaro5.com/forums/showthread.php?t=599161
Old 09-28-2024, 02:44 PM   #3
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Why not just eliminate the cats? I have NPP with headers and no cats and rarely open them. The mufflers keep the drone down and the cat removal made it louder. Open pipe from the NPP is a little raspy in my opinion..
FasNuf is offline   Reply With Quote
Old 09-28-2024, 06:19 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
If you don't have emissions testing, as mentioned, take out the cats. Even though they are "hi-flow", they do take away some good sound volume.
Old 09-29-2024, 05:49 PM   #5
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
I did that write up and it's still working flawlessly. Lmk if you have any questions and I can try and help you out!
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
