Old 10-09-2024, 07:27 PM   #1
BamaGearSlama
BamaGearSlama's Avatar
Drives: 62 Chevy II, 63 F100, 16 2500 LTZ
Is there a way to charge the battery from under the front hood?
I currently connect my CTEK charger through the trunk but get tired of removing the aftermarket liner and factory cover just to get to the battery.
Didn't know if I was missing something?
Many thanks in advance!
BamaGearSlama is offline   Reply With Quote
Old 10-09-2024, 07:46 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Most chargers come with a pigtail you can wire directly to the battery. I use the jump post in the engine compartment and stick the pigtail through the grill, with extension wiring coming off the jump post. It’s plugged in all the time, when not being driven.
0stones0 is offline   Reply With Quote
Old 10-09-2024, 08:30 PM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Yes, it's how I'm plugged in all of the time. Pop the hood and there's a remote positive terminal on the driver's side, and there's a remote negative near the airbox
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 10-10-2024, 08:07 AM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I hook the pig tail to the battery and run it up the truck and plug it is, All I have to do is pop the trunk, Some put the pig tail though a plug in the trunk and reach under and hook it.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-11-2024, 10:34 AM   #5
BamaGearSlama
Thanks for the suggestions guys!
I have the pigtail connected to the battery in the trunk now. I'll take a new look into both areas now and go with one of them.
Many thanks for your time!
Old 10-12-2024, 11:12 AM   #6
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
That is the way I connect my trickle charger (battery tender) too! Works great.
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 10-13-2024, 01:52 PM   #7
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
apologies in advance for the dumb question but what's the difference between charging keeping the trunk open and doing it keeping the hood open?
why are you trying to hard to charge it from the front?
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 10-13-2024, 06:10 PM   #8
0stones0
It don’t come easy.
0stones0's Avatar
Hood doesn’t need to be open. Or the trunk, for that matter. Depends how you wire it. Out the front of the grill and probably a decent spot in the rear so you don’t have to open anything.
Old 10-13-2024, 09:58 PM   #9
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
You have to remove the tire well cover to access the battery. Hooking the maintainer up under the hood is just easier.
69L48Z27 is offline   Reply With Quote
Old 10-13-2024, 10:43 PM   #10
Joe.G
Joe.G's Avatar
I leave a pig tail up from the battery it is very easy to access and is not in the way, less clutter under the hood as well.
Old 10-14-2024, 12:26 PM   #11
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
+1
Old 10-15-2024, 05:13 PM   #12
Icemen125
Drives: 1969 Z/28, '15 Z/28
you can just extend the length of the wires for your pigtail so that they stick out just outside of the spare tire cover / floor mat. Simple cut, solder, and shrink wrap. For a while I would just keep the trickle charger plugged into the pigtail, and just unplug the whole charger from the wall and store it in the cars cargo net when I go out and drive.
Icemen125 is offline   Reply With Quote
Old 10-15-2024, 05:55 PM   #13
Joe.G
Joe.G's Avatar
They make longer pre built pig tails .
Old 10-24-2024, 11:41 AM   #14
ChibiBlackSheep
I personally need to park my car facing forward in the garage, so I do the front. I don't always keep the hood open, during longer winter storage, I run it down and out the bottom and then cover the car.
