![]() Drives: 2010 Camaro SS Join Date: Jan 2023
L99 Cam Questions
Recently had a dod failure on my 2010 Camaro SS l99. I have now since bought a BTR Stage 2 V2 cam kit. I'm planning on taking my time piecing the car together at my friends house but for when the car is put together is it safe to drive it home i live less than 10miles from him. I plan on putting it back under a cover until I save money and get everything situated with a tune shop. Could I drive it to the shop as well? And along with this cam I am thinking of doing short tube headers would that be a bad thing?
KingRW3 is online now Report Post |
Just as I was thinking.. Read through this info. I would flatbed it, or trailer it home, and to the shop..
https://www.camaro5.com/forums/showthread.php?t=595872
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
When I installed the TSP cam in my car a couple winters ago I sent my PCM to them while it was apart, which is Mail Order Tuner and they sent it back, I installed it cranked it right up and it runs perfect. I would think you should be able to do the same with BTR.
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
There is no use of short tube headers. Long tubes are the only ones that will give you any increase in power. Do it all at once so you only pay one tune.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Yeppers, shorties are a waste of money, unless you live in a state that doesn't allow LT's. They do not gain you much over the stock manifolds..
#6 |
![]() Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Definitely get it all done at once so you only have 1 tune. I spent a lot of extra money on tunes because I have had 3 tunes since moding my car. 1 for the full bolt on tune, then another for the converter and finally when I did cam, heads gears I needed another tune. Don't know how much tunes are by you but here they are 400-700 a pop if you dyno tune like I did.
#7 |
[QUOTE=1JEWLDSSRS;11452344]Just as I was thinking.. Read through this info. I would flatbed it, or trailer it home, and to the shop..
But that's begs the question how would I know if there is any leaks or any mechanical issuses or even filling the engine with coolant and oil before it goes off for the tune? |
#8 | |
#9 |
Well from what I gather from seeing some other posts, and what we did with my Camaro when we did the cam swap, if you have everything installed correctly, and all buttoned up and filled with fluids, you can start the car up and run it to check for leaks, but I wouldn't rev it or do any driving of it until it is tuned. It'll run, but not very well because the ECM won't know what to tell the engine to do with the new cam profile.
#10 |
GPI Sales Consultant
L99's require a tune in order to run properly after an AFM delete. The ECM will look for the VLOM, and when it doesn't find it, it will assume that it no longer has control of the valve-train for those cylinders, and will disable the fuel to them and run as a V4. Combine that with a bunch of other tables not calibrated for the changes that the camshaft requires and it will run extremely poorly, and is not driveability in any sort of practical way.
Got a question about a GPI product? Feel free to shoot me a message! |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
On some GM this will also set a permanent DTC that will never clear since it can never get a passing test. Doesn't matter if you don't have to pass emissions testing that looks at codes since you can just turn of the light for that code. And in some jurisdictions, it won't pass the test even without the code. But there seem to be some jurisdictions that the cam change will pass but the permanent DTC won't.
#12 | |
#13 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
This was my concern when asking about AFM lifter failures in other threads. Many treat these as 'business as usual' and a good excuse to upgrade. Which it might be however, it's still bullshit, in my opinion, that us L99 people are relegated to driving ticking time bombs. And that it's just par for the course to potentially grenade a $12K motor. .
