![]() Drives: 2010 Camaro SS 6M Join Date: Dec 2024
2010 Camaro SS won’t move after clutch drop
The other day I went to do a burn out and did the normal rev to 4 grand and drop the clutch, well she hopped a bit and then all the sudden no movement from the tires but then engine revved up. There was no clutch smell or smoke of any sort but then I realized I couldn’t get the thing to move, after trying a few times I managed to get it to engage and roll a few feet but it popped loud enough to feel it a bit and disengaged again. Haven’t been able to get it on a lift yet but just thought I’d try to get ahead and see if anyone has experienced anything similar? It’s a 2010 as with about 41,000 miles on it
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Happened when I broke my axle and when I broke my driveshaft. Don't try to get it to move any more until you look at the underside. you are likely making things worse.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
Still curious on the update. Like other commenter said, probably broke an axle; although breaking the stock driveshaft u-joint might also not be uncommon either. Let’s just hope you didn’t break anything inside the actual rear differential…
![]() ![]() ![]() ![]() ![]() Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi Join Date: Apr 2009
Early 10's had a bulletin for soft transmission output shafts.
#5 | |
I never engage in anything that requires the clutch to be dropped abruptly (clutch kick, etc.), so I mostly modulate the throttle mostly. As much as I wanted to build my 2010 2SS into a budget drift build, I’m definitely keeping it as a semi-reliable daily driver at the moment… Hell, I even change the rear diff oil in it like once a year, since it’s easy enough to do with the tools and ramps I have. The factory LSD in the car doesn’t really like doing donuts and drifting, as I found out rather early on. I believe I lifted one rear wheel at a time at some point early on and checked the break-away torque, but didn’t seem to find anything abnormal. It just seems like the stock posi likes to one-wheel on turns much more than anything in a straight line. |
| Tags |
| clutch drop, drivetrain, won’t move |
