Old 01-28-2010, 08:18 PM   #1
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Broken yet accurate gas gauge I’m Stumped
Any of the experience mechanics ever seen that?
All of a sudden I cannot fill the tank in my wagon.
[1980 Buick Electra Estate Wagon]
I can only get a tad above half and its coming out the filler.
Though it reads use proper, I let it get down to 1/4 and its a squeeze to get 5gals back in. 22gal tank, all new fuel system. tank, lines, pump, carb..........
Still the original sending unit though and ill drop it to change it, if I have too [when it warms up] but it seems odd, if its broke, it shouldn't be accurate on usage between half n a 1/4 ehy?
2ndgenz28 is offline   Reply With Quote
Old 01-28-2010, 11:35 PM   #2
derklug
derklug's Avatar
Drives: 12 Boss 302
Check the vent hose, it could be kinked, or water could have froze in it. Take a gas can with you and try running the car out of gas. If it actually runs out as if it only had a half tank, it is not the sender. If you get a full tanks worth of driving, it is the sender. Just my guess on a web diagnosis.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 02-01-2010, 12:28 PM   #3
MLL67RSSS
Drives: car
So basically when it's full (gas coming out of the filler neck) it only reads a little over 1/2 tank, and when you use about 5 gal (which is near 1/4 tank) it drops 1/4 from 1/2 to 1/4 on the gauge. So the sender is trying to work. Since it is a new tank and everything the first thing I'd do is check the sender ground to make sure it is good. There should be a wire (black usually) from the sender to the chassis, if it's not getting a good ground the scale/range the gauge shows will be out of whack.
MLL67RSSS is offline   Reply With Quote
Old 02-01-2010, 01:54 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Thanks, thats a good lead right there.
With all the snow n salt it could not be grounded right.
Old 02-01-2010, 01:58 PM   #5
Mister HP
Mister HP's Avatar
Drives: Speed Shop owner
I have seen this on Chevy Blazers, they have an anti-siphon valve in the event of a rollover, and it gets stuck in the closed, or semi closed position, causing fuel to spill out the filler. I have no idea if your Buick wagon uses something similar, but it may be a place to look
Ed
Mister HP is offline   Reply With Quote
Is Gas Baffle Broken? mck17 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 01-27-2010 10:06 PM
AeroForce Interceptor Gauge Install tjd24 Audio / Visual / Electronics/ Gauges / Nav 7 10-21-2009 09:38 AM
SS on gas gauge? bucklwi1 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-02-2009 10:33 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
